>It's a little bit bottom heavy as I continue to try to find ways to accurately measure thin walled deep vessels. I'm guessing that the top 2/3 is somewhere less than 3/16" and the bottom is probably +/- 1/4". I used an Ellsworth style caliper, but upon releasing the vessel from the lathe, it weighed more than I'd normally want.
Overall, it's about 10" tall by 4" at the widest, hollowed through a 5/8" hole. I turned it end grain to maximize the spalt line. I rived off a windshake yesterday and mashed my thumb or I would have finished hollowing it yesterday...
>It still needs quite a bit of help staning upright. I like rounded bottoms (Oh, could I get in trouble for that...!) so it's got a small 1/2" flat spot to rest on.
>Hello, Steve. Beautiful piece of wood, and a beautiful HF! It's good (as Jorge stated) that it has a little weight in the bottom, if the foot is only 1/2"! :)
Steve, if I'm not using the laser rig, here's how I do it: Using my depth guage (dowel, through stick, w/knobscrew) I drill to the bottom thickness I want with 1/2" bit. Then I hollow. When I get near to the bottom (say about even with the lower curve to bottom), I stop the lathe, put the cutter at the deepest spot on the sidewall, and mark the toolshaft at the toolrest, and note the angle of it. Then I work across to the center whole at or near that same depth. Then I turn from the center hole outward, taking a light cut, swinging my cutter in an arc, trying to keep the tool shaft from going any farther across the rest, to smooth-arc the bottom. Of course, with each successive cut, the mark will move a little farther across the rest, but I go carefully making sure it's just the depth I want the next cut to be. Each cut is a smooth transition to the left, in an arc, lightening the cut just slightly and drawing it back just a little, when I reach the sidewall angle, trying to keep from going too thin, or, through. I keep this up until I reach the bottom of the center hole, and I'm done. this will leave the bottom curve just a little heavy, but with a narrow bottom, it's needed.
(I haven't tried to explain this before) Does it make sense? I hope so... I understand it fully... :)
>I turn hand held with Ellsworth style hollowers. I actually had a 5/8" bar in the 5/8"+ hole and I managed to get it this close. I would have cut more, but I could not tell how much wood was left. I cut through more HF's at that bottom curve than I can recall.
My issue is that as I strive to cut a HF of this size through a 5/8" hole or smaller, I can not reliably measure the thickness below 1/8" through a 5/8" hole 10" deep.
I think I might start messing around with some steel stock tomorrow to see if I can come up with something...
>I have several figure 8 type gauges that I have made. Rather than make them symmetrical, I make them with four different shapes for each arm.
As long as the ends are an equal distance from the middle hinge pin, or screw, then the opposite end will show the same thickness as the other end.
I start by making a fairly straight arm with a sharp crook at the end, and pair that with the arm with the deepest loop. On the other end I have two other loops with differing curves. The variety gives more options when trying to reach into those tight spaces.
Remember though that when you are reaching to the bottom of a turning like this that if that largest loop which will be the one in the mouth of this type of turning, will need to be curved enough to reach the bottom and be measuring straight through. If it is not, then as you view the opposite end, you will need to remember that you are reading the thickness at an angle, any you will need to visualize that same angle at the other end.
I have each leg stepped off in one inch increments, and do the same on the shank of my tools back from the cutting tip, so if I feel a small rib or bump at say 8.5" deep with the feeler, when I stick the tool in, I know that I am on that rib when I turn the tool on.
Oh, I measure to the rim of the turning rather than the tool-rest as stated by an earlier poster. I also like having a foot switch, so when I insert the tool, to the mark, and find and feel of the chosen spot, I can just move the tool out maybe a quarter of an inch, then turn the lathe on, and proceed to cut knowing exactly where I am down in there.
That is a nice turning, by the way. What is the shape of the tip that you are cutting with on that end-grain?
>The boring bars I make are all straight shank steel with a 1/8" round nosed cutter. When you use a depth hole (I drilled this one with a spade bit on an extension), you can essentially use a straight bar with the straight cutter inline and feel for the hole.
Since the cutter only sticks out 1/2" on my straight bars, the bar stops when it hits the hole. I take a backwards pull cut from inside the hole to widen it, then I use a cutter set at about 30 degrees on another bar. In practice, I'm only cutting endgrain when I drill the depth hole, since the cutterworks along the "side" of the depth hole. Little by little, I get deeper and deeper...
If you could post a picture of your caliper set and the practical uses of each, I'd appreciate it.
Nice looking hollow form. I wonder where you got that spalted maple from :>))). Would you post a close up picture? What finish are you going to use? Looks like you are having a lot of fun.
