FUNERAL URNS
FUNERAL URNS
FUNERAL URNS
Bill Dotten
>I have been asked to create some funeral urns for division of remains to family members. The family has some Walnut trees just cut. I can't remember the volume of a full sized urn nor do I know how large an opening is needed to fill the urn.Please help.
Re: FUNERAL URNS
Re: FUNERAL URNS
Stuart Johnson
>It is my understanding you need one cubic inch for each pound. So a 150 pound person needs an urn that will hold 150 cubic inches. I don't know about the size of the opening.
Re: FUNERAL URNS
Re: FUNERAL URNS
RevDoug
>Opening approx. 2". A 2" clean-oput plug is just right.
Turn 'em round,
Re: FUNERAL URNS
Re: FUNERAL URNS
Jason Clark
>Bill Grumbine has a page showing his process for turning a funeral urn. He lists the volume as 225 cubic inches, just under 1 gallon.
http://www.enter.net/~ultradad/urn.html
Jason
Re: FUNERAL URNS
Re: FUNERAL URNS
Allen Neighbors
>If they're going to be dividing him up among their family members, I'd use this formula: Weight of deceased divided by Number of Urns equals the cubic inches required for each Urn.
For instance, if he's 200 pounds, and he's going to be divided among his 3 kids: 200cu in / 3 Urns = 66.6666 cu in for each urn.
Make sense?
Isn't this awful? :)
Re: FUNERAL URNS
Re: FUNERAL URNS
Duane Hill
>One of our club members contacted a local mortuary for an urn he was going to turn. Here is what they said:
"Talked to the funeral director about cremations. He described the process (burn the body and then pass the remains thru a grinder to crush the bones to a dust - no big pieces are left). The funeral director said that the size of the remains is determined by the size of the skeleton, not the body weight. For those of you who want to turn an urn, the urn should be able to hold about 14 cups of rice. He said that will be able to hold 99.9% of the humans."
Re: FUNERAL URNS
14 cups of rice
Stuart Johnson
>A cup is a little over 14 cubic inches so 14 cups is about 200 cubic inches. The size of grain (rice vs. dust) would certainly makes a big difference in the amount a cup will hold. There is more air space in the rice.
I would contact the funeral director to be certain. One other option is to turn sufficient vessels of a pleasing size and shape. Divide the remains and if there are any left over scatter them in loving place.
Re: FUNERAL URNS
Re: 14 cups of rice
Ralph
>200 cu in is what is listed as the standard in almost every web-site
Re: FUNERAL URNS
Re: FUNERAL URNS
Mike Brazeau
>You can easily put ashes through a 1" opening, especially if you are dividing them into several urns. Last fall, someone posted an excellent method of making a screw top closure by using ABS plumbing male and female threaded fittings fitted into the vessel and top. I have it pasted in a Word document, but didn't give credit to who did it. Tried to find it here. but can't seem to find it. Could forward to you if you want. Just send me an email. Portions of water bottle tops and caps could also be used in a similar fashion.
I made one for my mom's ashes a couple of years ago and epoxied the lid in after filling with a portion of her ashes. Have yet to make the other small vessels for my sisters to have some of the ashes for scattering.
Re: FUNERAL URNS
Richard Allen
Re: 14 cups of rice
Richard Allen
>Actually 14 "cups of rice" is 156 cubic inches (;->)
14 cups of flax seed is 213 cubic inches
Re: FUNERAL URNS
Re: 14 cups of rice
Mark Kauder, Phenix City, AL
>Clear this up for me. Why would rice differ from flax seeds? 14 cups is 14 cups, regardless of the contents. Since we are talking volume. Based on the density and size of individual grains, it will weigh more of less, but the volume remains the same.
It is the inverse of the old logic joke - which is heavier a pound of feathers or a pound of steel. They are both a pound. The volume needed to make each differs though.
My wifes remains are all contained in a box that is about 4"x6"x8". They weigh what they weight, but filled with lead shot it would be much heavier, but the volume the same.
Mark
Re: FUNERAL URNS
Re: 14 cups of rice
Jim Shaver - Oakville, Ontario
>I dissagree...
14 cups is 14 cups........you have confused me with your logic.
take care,
Jim
Re: FUNERAL URNS
Re: 14 cups of rice
Stuart Johnson
>Mark, It is not the weight the rice vs. flax but the size of the grains. A cup of flax will be more densely packed than a cup of rice. The one cup of flax will contain less unused (air) space than the cup of rice. At least that is what I think.
Re: FUNERAL URNS
Re: 14 cups of rice
Stuart Johnson
>Okay, let's try this way. Take a measuring cup and fill it with one cup of dry rice. Now put that cup of rice in a coffee mill and grind it into a powder. Dump it back into the measuring cup and see if you still have one cup.
Re: FUNERAL URNS
Re: FUNERAL URNS
Jorge Castaneda
>Bill
I have not read the other responses, so I may be repeating:
The full size standard is one gallon, for a very large person figure out a cubic inch per pound, the opening can be as small as the opening of a milk jug or larger of course.
$0.02
Jorge
Re: FUNERAL URNS
Re: FUNERAL URNS
Jim King
>I would suggest you make them bigger than you think they should be as per published recomendations. We just sent a guy back to the States with the one cubic inch per pound rule. His wife left with a bit in her purse. The heat does not always burn all the bone and here we get what is left. I assume in the States they sift what comes out of the oven to make it look more presentable so the one cubic inch per pound may apply.
Attached is a photo of several urns and one is a double that is to be decided on before death who gets the top position.
Re: FUNERAL URNS
Re: FUNERAL URNS
Jim King
Re: FUNERAL URNS
Re: 14 cups of rice
>That is exactly what I was saying Stuart. The other post was saying that 14 cups of Rice was X, and that 14 cups of Flax Seed was Y.
Mark
Re: FUNERAL URNS
14 cups of rice..............
Barry Turner
>Fourteen (14) cups of rice........makes you feel kinda insignificant doesn't it?
Re: FUNERAL URNS
Re: 14 cups of rice..............
>Especially when they tell you how much it is worth.
Mark
Re: FUNERAL URNS
Re: 14 cups of rice
>Yes, Stuart, I still have a cup. A cup equals approximatel 14.28 cubic inches of volume. However, would no longer have a cup in volume of rice. I have moved more of the solid rice starch into a more compact form, and put in the bottom of the container, and moved the air that had been evenly distributed thoughout the rice/air mixture, and now moved the air to the top of the cup container.
Volumetric measurements (cubic inches for example) are defined by the container, not the contents. A gallon jug is 231 cubic inches regardless of what is in it.
The discussion was not how much rice you could put in a cup, the discussion was how many cubic inches you need to have for a funeral urn, and the example was about 14 cups of rice (or about 196 Cu.in.)
Mark
Re: FUNERAL URNS
Richard Allen
Re: 14 cups of rice
Richard Allen
>It has to do with rice. A "cup of rice" is a smaller measurement than a cup. A "cup of rice" is 180 ml and a cup is 250 ml.
A cup of rice is 1/1000 of the amount of rice needed to feed one person for a year. This has nothing to do with the imperial or British measurement systems. Except that an object that looked like a "cup" was used to meeter the rice for cooking. Rice cookers are a staple of most Asian homes. Those rice cookers use this smaller "cup" as the measure of rice.
Re: FUNERAL URNS
Ric Taylor
The Opening can be Any Size You Want
Ric Taylor
>There are no rules about the design of an urn. There are some generally traditional shapes, but you can go with any design you desire. You only need to be concerned with the volume of the vessel.
Ric
Re: FUNERAL URNS
Re: The Opening can be Any Size You Want
Bill Dotten
>Thanks everyone you solved my problem
Bill
Re: FUNERAL URNS
Here is a little more to work with.
Keith Newton
>Bill, A cubic gallon is 231 cubic inches, and that is more than is necessary for most.
If you use a wood with voids, they can slip an empty bag inside a small opening, then funnel in the remains through a very small opening. Or they can be divided up into small bags that can be squeezed in separately.
If you need help in figuring the volume of a sphere, I think the formula is
4/3 pi X the radius cubed.
I did the math once, and I think it works out that out a gallon is a sphere which is a little under 8".
