New Rack
New Rack
New Rack
>Had made myself a mobile tool rack that rolled around the lathe on an old office chair base. Worked ok but it was never where I wanted it at the moment and, being built in a circular format to save space in the Shoebox Woodshop, the tool I needed was always on the opposite side of the circle(of course).
Therefore I scraped together some extraneous pieces of 2" PVC and put this new rack on the wall to have every tool within easy reach and a step or two. The individual tubes are open at the bottom so that any shavings simply fall right on through and wind up on the floor as the stops are slanted at a 30* angle. Got the basic idea here on WC, but don't remember whose post it was.
mm
Re: New Rack
Where did you get the gray paint for the lathe.:-)
Eddie Pacheco: San Jose, Ca.
Re: New Rack
Standard Issue
>But available to all. Hammerite Rust Cap #8544 Grey.
$7 per can.
If, however, you want the lathe to go with it, that'll cost you a bit more. |;-}}
mm
Re: New Rack
Re: New Rack
Joe Donohue
>Mark, this looks really well designed. Would you mind posting a larger image so we can see some more of the details?
Joe Donohue
Re: New Rack
I'll Try
Re: New Rack
Here Goes
>I hope you can see the 3/4" plywood tube holder here as well as the small beveled strip with a tab to catch the ends of the tubes. Holes for the tubes were drilled with a 2-3/8 hole saw at 3" O.C., then the PVC is held with hot-melt glue applied like caulk around the tubes plus a brad and a glob of hot-melt at the bottom edge. Upper tubes are 8" long for shorter tools; mids are 10" and the bottom grays are 12" long to hold long gouges and boring bars. The 2" PVC is a good size as it will hold any handle I can grip or all three of my Jordan bars fit into a single tube.
Re: New Rack
Re: New Rack
KEN RIEDEL
>Mark - I have a similar set-up for my tools, that is, behind my lathe. (I ALWAYS SHUT OFF THE LATHE BEFORE REACHING FOR A NEW TOOL.) I had a student come for lessons & he suggested putting hinges on the side, so that the tool rack would pivot to where I could easily reach it. WISH I WOULD HAVE THOUGHT OF THAT!
Re: New Rack
Talk to Al
>Crandall. He's copying my swing-away tool rack for several people in his club. The pic is the application to my old 1236.
Re: New Rack
Pic 2
Re: New Rack
Re: Here Goes
Joe Donohue
>Thanks Mark.
Joe Donohue
