Grizzly 0462 Lathe
C.W.Stivison
>Does anyone have any experience using this Grizzly Lathe.
Thanks CW
Grizzly 0462 Lathe
C.W.Stivison
Thanks CW
Re: Grizzly 0462 Lathe
Ian
>CW,
I've had the lathe for almost two months now.
When I first got it, the speed adjustment was sluggish. figured it was the reeves drive needing greesing, found out it was a cracked pully causing the problem (assumed hidden shipping damage) grizzly replaced the pulleys with in 7 days.
the pully shafts did need a good cleaning and greesing when I took it apart, I think they are using used axle greese for there lube.
anyway, after putting things back together, the speeds change smoothly and the actual range that I have is 580 to 2710, digital readout is nice.
the spindle height is 43 inches, I like mine at about 47 so I raised it up on 4 x 4 blocks, also the leg width seams a little narrow so I made the blocks 24 inches long for better support.
only had one large (14 in dia, 8 in thick) out of round block on the lathe so far. It danced nicely, but not to the extent that I couldn't get it to round out and under control. I figured when I bought it that at 300 pounds this lathe was going to be light, so as soon as I get a chance I will be adding a weight box with at least 250 to 300 lbs of lead or sand in it.
Now....I bought this lathe knowing it wouldn't be my last purchase, but I needed a low cost lathe to replace my craftsman that was going south fast, and I didn't want to spend any more money on. I also didn't want to tie up a thousand dollars on one of the more common choices (ie, delta, jet, etc.). So at $375.00 dollars the grizzly fit the bill.
hope this helps.
IAN
Re: Grizzly 0462 Lathe - echo Ian's comments
Ray Carson, Lawrenceville NJ
>CW,
I haven't used mine too extensively yet but am quite happy with it. I'm just returning to to the "round world" and I was also looking for a decent lathe without taking out a second mortgage as Ian stated.
Speed change from low to high is tight and I probably should do as Ian has done. Speed change from high to low is good. I can see where adding weight would benefit this machine but I've turned some baseball bats and some small irregular shaped bowl attempts with no problems.
I'm a big Grizzly fan as some here know. One of my beliefs is, you get what you pay for. I don't mean that good or bad. It's just my experience and my experience with Grizzly products. If you have a big budget, go for something better. I like their products.
The digital readout is very handy. There is no indication of speeds otherwise.
Just my two cents worth,
Ray
