Angle drill bearings
robo hippy
>A while back I posted about some fancy bearings that I got, on an engineers recomendation (supposed to be better quality than the Koyo bearings others have recomended), for my angle drills. I just went through the first set. I got somewhere between 350 and 400 bowls, most of which were in the 8 to 14 inch diameter range, out of them before they (3 out of the 6 in the drill) failed. This was the only time that I heard them go out, with a small tick sound, then 5 minutes later, the drill stopped. Usually they start sounding bad slowly, and get worse over the course of a week or three. I am getting them done again, and will keep better records of how many bowls I get done with them, then get a brand new drill with stock bearings and see if there is much difference.
I asked the repair guy if he knew why they failed. He said that it was the dust. I said that the bearings were supposed to be sealed. He said that eventually dust still gets in, and that using the drill for a sander was exceeding the intended use and abuse of the tool. I do use 3 inch discs exclusively. I figured that maybe since I was now running the discs at a slower speed, that the drill bearings might last a bit longer, but it doesn't appear so, at least not on this set.
Testing still in progress.
robo hippy
Re: Angle drill bearings
Darryl Hansen
>I assume you are using the Milwaukee/Souix drill. Try blowing out the drill periodically with compressed air. You'll be amased at the amount of dust that collects around the rear bearings. The front bearings are coated in grease the rear ones are bare and prone to fail first. I've used the blowing out process on a drill and after aobut 200 different types of stuff it is still going strong.
>I wonder if it's the side loading of the bearings. Drills were designed so you push directly down througth the chuck. We are pushing the shaft sideways when we sand. Just a thought.
robo hippy
>Yes, I do blow out the bearings several times during a sanding day. I have thought about putting a baffel on the rear exhaust on the drill, so that it blows towards the intake, which would blow some of the dust away from the intake, and more in line with the dust collection hood. The lateral pressure probably has a lot to do with failure also. Most of the drill bits won't exceed 1 inch, so that is a lot of side pressure. I have worn out 2 or 3 casings on the drills, in the head that supports the chuck. The one that has proven to be the most durable is one of the old black ones. I haven't tried sanding till failure with 2 inch discs as I seldom use them. If I can get a 3 inch disc in side the bowl, that is what I will use.
robo hippy
Darryl Hansen
>Another thing I use is a filter. I use the stuff they sell at the box stores that you put in your floor A/C vents. It comes in 4x9" strips or so. I tape a piece of it over the intake vents on the frill and change periodically. The tape makes a mess of the body but the amount of dust the filter catches is considerable.
Mark Kauder, Phenix City, AL
>I would also suggest that you get some dust collection setup as close to where you are sanding the bowl. Once you do that, you will see a good deal less dust coming out of the drill when you blow it out.
Mark
Re: Second That
>Have had my Sioux (2500 rpm) for 4 years and still working on the first set of bearings, but with DC hose right next to the piece being sanded.
mm
