THE WOODRAT IS BACK!
Powermatic 4224 owners?
John Kyler
>I have a spindle turning job that is developing into a need for a larger lathe of at least 20" swing and possibly 24". I can get a good price on the PM and would like to hear from those that have turned on it what you like or not?
Thanks
John
Re: Powermatic 4224 owners?
>I have the 3520A and have turned a fair amount on a 4224. I like them both. The 4224 is larger and therefore takes more floor space. It is also heavier which is great for turning large or out of balance pieces. The tool rest is also heavier and a little harder to move but does move easily. I like the sliding headstock of the 3520 but mostly it fit in my price range.
RPE
>Give Toolnut a chance at your price. They will beat any price. Any. I got my 3520 and my PM 66 from them. TOOLNUT.com
Roger Dunn
Roger Dunn
>John,
I've had my 4224 for two years. The only two beefs I have with it are the on/off button is positioned on the headstock at spindle height and when turning the inside of a large bowl's interior at the headstock end, I frequently bump the button with my hand and have to restart the machine. The other inconvenience is the motor is mounted under the ways at the headstock and the space above the motor clogs up with shavings so it is hard to get the banjo or a bowl steady moved around above the motor because of the accumulated chips. Those are minor irritants and other than that I love the machine for it's quiet, smooth operation. I hog out heavy unbalanced pieces and the electronic controller has only had to be reset once because the thing lugged down. The General 260 I had before this lathe was always cutting out and it was a pain to keep resetting the controller. If you are anywhere near Western Washington and would like to take a test drive, feel free to contact me and you can come play on the machine.
Roger Dunn
Roger Dunn
>John,
I forgot to mention where I got my lathe, It was from Neal Ferko at Equipment Sales and Surplus in Auburn, WA. They are a distributor for Jet, Powermatic, and the rest of the equipment sold by Jet. They are also an outlet for the 'scratch and dent' products. They too will be aggressive in pricing so you might be able to get them in a bidding war with Tool Nut for your wallet. Their website is:http://www.equipmentsalesandsurplus.com/
I have no affiliation with this company but am a satisfied customer.
Good luck.
Re: Here is a fix for that pesky clog.
Al Crandall (N.E. of Indy)
>I turn on a PM4224 as do two of my buddies who live nearby. All three of our lathes have the following modification to help clean out those chips above the motor. Remove the two (or maybe it was three) screws which mount the sheet metal cover above the motor. Use your thigh as a bending form to put a smaller radius bend in the cover before remounting it. The resulting gap between the front edge of the cover and the lathe bed will allow chips to easily be pushed or blown through to the floor.
My only dislike on this lathe is the fact that some of the bearing area for the MT2 shanks inside the tailstock quill has been machined away. This reduced area means less holding power on the shank of the drill chuck, and occasionally the chuck will spin inside the quill under heavy drilling conditions. I don't remember the drill chuck ever coming loose from the grip of the quill in the Monarch metal lathes at work.
Roger Dunn
Thanks Al!
Roger Dunn
John Kyler
>Thanks for the tip.
I work at one of the larger tool/hardware companies and can get it well below wholesale cost a couple of times a year and will be doing that. But otherwise I would be looking for the bargains..
John
Re: Powermatic 4224 owners? THANKS!
John Kyler
>I want to also say thanks for all the responses. I will be buying it using an employee tools order from where I work and can get an outstanding price.
I looked up the price and this is the way I will be going.
John
