finial leather dye
gary s clarke
>I want to dye a finial (maple) with black leather dye and would like to know what type of sealer to use before using the dye. Any other hints or finishing tips on finials would be appreciated. thanks
finial leather dye
gary s clarke
Re: finial leather dye *LINK*
joaz
>I have not used leather dye before but I get good results from stove black. It contains some kind of wax that lets it buff out to a nice semi-gloss sheen. I then spray on spar varnish.
sorry no help with the dye but you might want to give stove black a try.
ShapeShifter Woodturning
Re: Gary- I have used leather.....
Jamie Donaldson
>... dye many times to make ebony out of maple, and you want to dye the wood before applying any type of finish. I dye finials while still on the lathe, and finish with a friction polish,shellac, or I sometimes use lacquer as a friction polished finish.
gary s clarke
>thanks Jamie, I will follow your lead.
Russ Babbitt Jr.
>I would say dye before finish. I have heard that black India ink is about the blackest material avaialable if your looking for options.
>I have used India Ink, shoe dye and analine dye to get some shade of black. I do this before finishing and will raise the grain with water and sand back before application. India Ink gives a very good black as well as Shoe dye. The biggest difference is whether they are water or alcohol based and what finish you are using over them. Shellac will make the alcohol based stuff run and smear so be careful with that.
Analine dye is good because you can mix some blue or red with it to change the Black into something a little cooler or warmer. It still looks black but you can get a different affect.
To get a real ebony look dye it brown with a few coats and then dye it black. Then steel wool through the black in places to give some brown steaks. If you go too far and hit wood just add more brown or black until you get the affect you want.
gary s clarke
>thanks to all for the great information. aren't turners at woodcentral great at sharing!
