tool rest
tool rest
tool rest
Tony Zaffuto
>Anyone out there able to give me guidance on what manufacturersmake tool rests to fit a Powermatic 45 wood lathe? The tool post is 1-1/8" diameter and I would like to stay away from round rests.
Thanks!
T.Z.
Re: tool rest
Re: tool rest
>The only people I know making tool rests make the round ones so I can't help you. I like my round tool rests.
Re: tool rest
Re: tool rest
JKJ in East TN
>I made my own (also round) by welding some steel stock. This was practically trivial, but it would not be much different to use a piece of flat or tapered steel instead of the upper round. Just cut the top of the post at the desired angle. I bought one made this way - it had a wide taper on one edge of a 2" by 3/8" thick flat steel bar.
Re: tool rest
Re: tool rest
Tony Zaffuto
>Thanks all! I already have a round tool rest and am looking for a rest to get a bit closer. I made this one and can make another, however my time is very tight. I will probably make one from angle iron or make another round rest and mill the top flat.
T.Z.
Re: tool rest
Re: tool rest
>Tony Check out the tool rests that the Robust lathe uses. I don't know if he would build you one for the older powermatic but I sure like the shape. They look like a 1/4 of a pipe so you get clearance from the banjo but you still get the tool very close to the workpiece.
Re: tool rest
Re: tool rest
Ed Heuslein
>Howdy Tony: I have several tool rests made by James Johnson in Kerville, TX and love them. They are 1/4" stock, bent about 40*. I think you can contact him at jjohnson17@stx.rr.com. If not, you should be able to find him in the AAW directory. And, his prices start at about $35.
Re: tool rest
Re: tool rest
Tony Zaffuto
>Thanks to all for the help. I believe I got a solution at hand! I'm usually hanging out on the "hand tool" side, but I also burn a few electrons!
