I'm getting set to begin some experimenting with texturing and dying and a question has popped up. What is the best material to mask a portion of the wood I don't want to texture?
>What kind of texturing are you talking about? Many of the texturing methods I use would pound through just about anything you could put over the area. For sand blasting you can use some types of shelf liner.
I use the Dremel engraver with a rounded bit for texturing. Using this tool you simply skip over that non textured areas. The same is true for textures done with the woodburner or leather stamping tools.
To keep dyes from bleading into areas you can woodburn first and then color inside these areas. You can also use spray on resist and cut out areas. You'll need some sort of spray applicator like an air brush or The CRitter to do this.
>For masking glass and other shiny surfaces when grit blasting, I used white paper fastened with double-sided masking tape. I would draw or print my pattern on the paper and cut it out with an xacto knife. I haven't tried this on wood.
The paper/tape held up fine to the silicon carbide grit I used. For something more agressive, tombstone makers can provide an industrial strength adhesive-backed masking material that will withstand the tremendous abrasion of grit blasting granite. (BTW, I got a sample once from a guy in Conn who turned out to be Ruth Buzzi's brother - you might not recognize that name unless you are pushing 60.)
>I am planning to use a steel wire wheel, then dye and lime to wood. I was wondering if there was anything out there that I could apply to the wood to resist the steel wire. Steel wire would destroy most tapes. Guess this is why it is called experimentation.
I have been playing with my Dremel and several tips and will be working with them too.
