Stuck faceplate on 3520
Pete (Stafford, VA)
>Help! I've loosened the set screws, but I still cannot get the faceplate to unscrew off of my 3520. It won't budge at all. Any else have this problem, and if so how did you fix it????!!
I finally have a few free minutes to get some turning done, and bam -I'm stuck....
Thanks!
Pete
Re: Stuck faceplate on 3520
Craig Daymon
>I use one of those strap wrenches. They are cheap at the hardware store if you don't already have one.
Then once you get it off, clean the spindle threads and spray it with a little WD-40. I also have those plastic washers, which are suppose to help, but since spraying with WD-40 (only necessary about once every 6 months and it doesn't take a lot) I haven't had the need for the washer.
-Craig
P.S. John Jordan also sprays his bed ways with WD-40 to make sure the tool rest moves smoothly when he wants it to and to keep it rust free. He also sprays under the banjo to keep the locking mechanism moving smooth. Least that's what he did just prior to demoing for our local group.
>Pete Usually the way to get it off is to use a big wrench. With the Powermatic it's easy to break the spindle lock so I would try not to hammer on it. Ruth had good luck with a big pipe wrench but your faceplate might have holes for a bar or a flat spot for a wrench. If it does use that. put a big pipe on those and give it a lot of force. Like I said I would avoid hitting the wrench with a hammer, the cast parts on the spindle lock can break.
Pete (Stafford, VA)
>Duh! Thanks Guys - the wrench worked....
Pete
