Salad bowl question
Charlie Anderson
>I'm about to start on a salad bowl set for a wedding gift.
My question is on the shape of the individual bowls.
Should the base be wider than the standard 1/3 of the rim diameter to provide stability?
Salad bowl question
Charlie Anderson
I use .4 x max diameter
TDaniel
Thanks Terry
Charlie Anderson
I made them with round bottoms
steve antonucci
>the bowls spin and rock like Weebles, but I've never seen a single crouton make the table... Same with candy and popcorn.
Steven
Re: Charlie- many years ago.....
Jamie Donaldson
>... when I was just starting to turn, I made a set of salad "plates" that my wife requested, and we are still using them today. They are simply flat discs with a rim and shallow recess about 3/8" deep made from a 1" thick walnut board. They even have the 3 screw holes filled with wood putty left from the faceplate mounting, but nobody turns them over to check when filled with salad!I've never seen any reason to replace all 16 of them with more recent work just because I am a much more experienced turner now, and would never leave evidence of how they were mounted!
Re: Salad bowl question
Jim Swank
>There's not that much difference between .4 and 1/3. There are other factors that affect usable stability. The foot, if it exists at all, should be minimal in height. The shape of the bowl bottom should be nearly flat at the base, curving gently upward. These factors will give the appearance of a lighter more graceful bowl, but can limit the amount of tip in normal use to perhaps 1/8" or so at the rim. It doesn't have to look clunky to be practical and useful.
