>Hey all, I'm thinking of maybe doing the interior of my shop (walls) with rough sawn lumber or reclaimed lumber. Does anyone have any idea of how to source this? If I can do it for around the same price as drywall, I think I would lean that direction. Thanks for any help, Sean
>Sean, Woodmizer (Indy) keeps a list of portable sawmill owners. If you give them your ZIP they will give you contact info on the 3 closest mills to you that can supply you with whatever you need. If you can sticker and stack 1" thick boards in a covered area or under a sheet of tin it will be dry enough to nail up board and batten style in 30 days or so this time of year. My shop is done this way and it is nice to be able to drive a nail wherever you need to hang something.
>I wouldn't care to spend the time and effort involved to dimension rough sawn boards to a uniform thickness and width. If you decided to leave them rough your walls would be dust magnets. Recycled barn might be an option but I think I would look at using OSB or 1/2" plywood if 3/4" was too expensive.
I just finished a feed/tack room in my barn with 3/8" plywood. I was not too concerned about the thickness, but it turned out plenty strudy - I get no flexing when pushing between the supports. I'll probably finish the inside of my shop the same way, put up with screws so I can remove panels if necessary.
>Bandsawn lumber, if the blade and operator are good, should be uniform in thickness and not nearly as rough as from a circular mill. Any piece of dust that is trapped on the wall is a piece that doesn't go into your lungs. :)
>Wafer-board (OSB) is about $.18 a sq.ft. Sheetrock goes for .28+-. Maybe you could buy decent rough lumber at .18 a board ft. I think the drying process would be the drawback. I sheet-rocked my shop but if I had it to do over I'd use OSB. Mike
>The price of 4 x 8 sheets of OSB is really down now. Last time I was in Lowe's it was around $5 a sheet - has been 1n $10 - $ 12 range at times in recent past.
>Sean, between you and me along US 60, there are several lumber mills. If you would like me to, I can ask around and get some names and numbers for you. Just let me know.
>Shawn, around here I can get my rough lumber planed and T&G with a minimum of planer marks for $100/MBF. The "V" groove installed vertical would be pretty dust free and have a nice appearance.If a person paid $150-$175 per thousand that is pretty cheap wall covering considering the product used.
>I wouldn't mind a nice look as this is a one time build and it will sorta be a home away from home. I don't see dust as a big problem with good dust collection. I can always open the roll up door and blow out the finer dust with a leaf blower.
