Bowl Depth Gauge Pics
Bill Grumbine (Kutztown PA)
>Greetings all
Last year when I was making my second video I developed a depth gauge that would work with any kind of bowl, hollow form, vase, whatever, as long as it had a hole in the middle. It was a shop wonder, screwed together plywood and some dowels.
Just this morning I received two prototypes of the same jig, only now in aluminum, and with some refinements to boot. They were made by the same gentleman who makes my vacuum chuck. I apologize for the cluttered background. It might make it hard to see a little, but that is the way my shop is.
Here is the new one. The design is essentially the same, but refined somewhat. The rods are adjustable and can be held steady with a knob. There are a number of holes to accommodate different sized lathes. The second prototype is actually sized for mini lathes.
The depth rod that goes to the bottom of the turning is blunt. The tip of the vertical measuring rod is sharpened like a pencil for accuracy. Below is a shot of it measuring a bowl from a piece of (gasp!) firewood I turned this morning.
Of course, people like fancy, so I asked for some high tech stuff. :D
It is not easy to see, but there is a hole drilled just behind the one for the rod which will accommodate a laser pointer. By adjusting the depth rod to meed the laser beam, I now have a laser guided depth gauge.
I have circled the laser beam for monitors that may not show it real well (like mine). I hope that the circle shows so you know where to look! As you can see, I need to make the bottom just a little thinner.
Like I wrote, this is a prototype. If anyone has a suggestion to improve it I would be glad to hear it. I have a few of my own, mostly minor stuff, that I discovered while using it this morning. And of course, if anyone has any questions, I will be glad to try and answer them.
Bill
Re: Bowl Depth Gauge Pics
Norm Smith in Nova Scotia
>Bill, It sure looks good to me. With the laser it should be very accurate.
Norm
RonZ
>Excellent! When will production start? If not where will you 'dump' the old ones? =o)
Larry In Lima
>Bill, Maybe It's there, I don't know but didn't see it..
Was wondering about some markings on the depth part of the whole deal, kind of like a ruler, with at least some basic measurement markings on it? Think that would be "do-able" or useful? I don't know, I don't use anything like this, but it is interesting for sure.
Larry
>Thanks guys, for the responses.
Norm, the laser makes it easier to use, and we all know that lasers make tools "sexier", right? I know I will be using the laser option because it works faster and easier.
Ron, I don't know when production will start. I have to make a few refinements and get them back to the manufacturer, but it should happen pretty fast. I would like it to be ready to go by the end of August.
Larry, I suppose it could be graduated, but the main focus is to see where the bottom of the inside of your turning is relative to the bottom of the outside. This is one of the toughest things for people of all skill levels. It really stinks if the bottom is deeper on the inside than it is on the outside, but it is almost as bad if the bottom is too thick, since it leaves the piece with a clunky feeling. I use this gauge in conjunction with a 6" rule. I mark the piece, or just hold the rule up to the spot where the pointer indicates, and measure to the outside bottom. That tells me exactly what I need to know to get it right every time.
Thanks again for the feedback, and I hope to read some more coming soon.
Bill
kenny in indep
>Oh good, one more thing to put on my must have list, make that the next thing. Really like the laser light addition. Thanks for your imput into the turning world.
Hi Bill
Dominic Greco in Richboro PA
>Bill,
Sorry I didn't get a chance to respond to this yesterday. But that nasty day job got in the way!:>)
I really like the set up for this depth gauge. What I like most of all is the "steady" nature. Since it sits on the lathe ways, you get a very accurate reading. While I love the simplicity of the plain "depth rod", I really like the laser set up.
Have you thought of embedding a couple rare earth magnets in the base? That way it would be held nice and steady on the lathe bed with less of a chance of tipping over. There could be a lever on one side to lift it free when you're done (like those magnetic feather boards). I know this if given a chance, RIGHT after I bought it and used it for a week, I would get clumsy and tip it over and bend one of the components.
See ya around,
Dominic
Re: Hi Bill
>Don't worry Dominic, if you bend something I will have spare parts for you! Balance was one of the first considerations, and at it stands right now (ha ha) it is balanced with both the stick and the laser in place at the same time. Magnets might also get in the way of making fine adjustments to the placement as well. Not that I know anyone like this, but I could just see some zealot strapping on a huge magnet, and then having to wrench the thing around to get it off the lathe. I'm glad I never do anything like that! ;-)
Bill
Tim GC
>Graduated Scale for accurate depth assessment. I can see the advantage a rod with graduations would have for finding accurate depth in hollow forms, rather than just base thickness, compared to bringing in more kit (steel rules etc.) but then you run into increased production costs outweighing the benefits. You say you could supply spares, it may be better for anyone to order a second rod and get the markings done themselves in whichever scale they should wish.
Just my �0:02p
>Bill I would like to see a way to put the lazar on the headstock. A good accurate way to set it especially when reverse turning the bottom. Then you would know exactly where the bottom should be and it would stay in the same spot as you removed wood. You could set it either for the thickness you want the bottom or where the true bottom is so you never cut that far.
