Re: drying green wood
GaryG in MD
>Hi Ken,
Fog and Barry have given you some very good advice. Let me add my experience FWIW, since I'm having problems that you may be able to learn from.
I live in Maryland, and it is what I would call "temperate" -- neither super hot or wet or dry -- just kind of average.
I believe that in your post, you were asking about hunks of wood (rounds or half rounds), not roughly turned bowl blanks. The problems are similar, but much worse with the hunks. Very simply, I believe most people will tell you to rough them out on the lathe as quickly as you can. That would certainly be my reco, based on my most recent experience; to wit:
Tree cutters came into our neighborhood a couple months ago and cut down a number of large trees. I don't like it, but they did, so I figured I might as well get some pieces rather than let them go to the chipper. First I made the mistake of not being able to chain saw all of them immediately, and I put some into plastic bags. Wrong!
Rule #1: NEVER put wood in plastic bags!!! I immediately started getting black rot, and that's very hard to get rid of once you get it (see Archive posts on bleach, boiling, etc.) I don't think it would be any different for you in your dry climate -- freshly cut, green wood has a lot of moisture in it, and if you keep the moisture in, it will probably start to mold/mildew/rot within a couple days.
I was planning to leave on vacation shortly thereafter, so there was no way I could rough it all on the lathe. I did my best, but I ended up with quite a few half rounds left over. I had carefully removed the pith and cut them into octogons with the chain saw, and waxed them all with Anchorseal or it's generic equivalent. I put them on stickers inside my house, in a dark room, to keep the temperature/humidity well controlled while I was gone. I thought I had done a good job and that these blanks would dry slowly enough for me to be able to rough them at a reasonable pace when I returned. WRONG!
Yesterday, I was forced to move all of these hunks out of the house because my wife and visitors were complaining/commenting about the fact that the whole basement smelled musty. Upon closer examination, I found that the largest percentage of them were either cracked (all 5 birch), black with rot (9 silver maple), or cracked and black with rot (7 our of 8 red oak and 4 silver maple). Needless to say, I am quite unhappy. FWIW, I have had better luck with black cherry, altho I also found 5 of them cracking.
What I have learned from this experience is that even if you try really hard to do the right thing, it is very difficult to keep unturned hunks of wood around for more than a few days as chainsawed, sized half rounds. You really have to leave it in log form and let the pith cracks take the ends or turn your bowl blanks. I have had much better luck drying bowl blanks, so I was really surprised with my poor results here now. I stacked them all outside in the shade and plan to do some serious roughing and see what I can salvage, altho it's depressing.
Your mileage may vary.
Good luck, Gary
