Timberwolf broke.....finally
TDaniel
>A couple or three months before the Gathering last year I put a new 3/8 x 3 tpi Timberwolf blade on my Delta bandsaw with riser and today it broke. That is about 18 months on the blade. I never release the tension or fiddle with it. It would have gone longer but I have been sawing mortise and tenon joints recently and the center cutout between tenons requires a tight curve. The blade still felt sharp but the new one cut much better so I know the old one was getting dull. That sucker has cut a LOT of wood. It did not break in the weld. Oh, and it has never been resharpened.
Re: Timberwolf broke.....finally
Ruth Niles
>TD, I have a Timberwolf blade that's been on my bandsaw about 2 years. Fred Hatton can vouch for that. It even got bent in a log, I straightened it with 2 pair of pliers and that was about a year ago. I love those blades!
By the way, did you ever notice a blade with a tick lasts longer than any other? ............ "just one more cut"
Tick?
TDaniel
>Hi Ruth, I tried some blades once that were welded without regard to tooth set. It seems that at the weld there was a tooth on each side of the weld that was set the same direction rather than alternating. The little aluminum plate that fills the hole would bounce out when the weld came through because of the incorrect set. After sawing the plate in half I learned to glue in in with CA and I still do that. Blades don't last long when cutting aluminum. :)
robert davis
>i bet timberwolf will replace it. they did one for me
Steve Kubien
where to find 'em
Steve Kubien
>That's quite the testimonial. Who carries them at a decent price?
Thanks,
Steve Kubien
Ron in Drums PA
>They didn't for me and the blade was a month old
order directly from timberwolf
robert davis
