>I have a Delta grinder with the attached light. Problem is I can't seem to keep a light bulb in it - they keep going bad. I suppose the vibration ruins the filiment or something. Tried "heavy duty" bulbs
from lowe's - not much better. Anybody got an idea?
>Try using a flourescent bulb from Phillips or better yet, the new LED ones. These are shaped like a standard bulbs but do not have the long filiments that will break with vibration.
>I would start with Bob's suggestion of trueing the wheels. Then get one of the bulbs designed for industrial use. I went to my local lamp sales place, not Lowes. I have these lights in my drop lights and you litterally can drop them and they won't break the filament. A really hard drop does but I've bumped them a bunch of times and dropped them off the fender a few times and they are still good.
>Anytime that you replace a standard light bulb you should "break it in" by letting it burn at least 3 minutes the first time you turn it on. Don't flip the switch to see if it burns and then turn it off. As others have suggested use a rough service bulb.
>It does sound like something is out of balance on your grinder. It shouldn't geterate enough vibration to shake out the filaments on your light bulbs. I did have that problem with the bulbs that I had in one of the Moffit lamps that I kept on my banjo. Switching to the rough duty bulbs helped that.
