Cutting Drill Rod
Cutting Drill Rod
Cutting Drill Rod
Eric Knutsen
>I just picked up O1 oil hardened drill rod to make some hollowing tools. What is the best way to cut a 3 ft rod into 1 ft usable sections?
Re: Cutting Drill Rod
Walt Ahlgrim
>Grind a groove in it with the Conner of grinding wheel about � each side. Wrap bar in a rag put the bar and rag in a vice groove just above the jaws, bend the bar with a hammer it will snap at the groove.
Walta
eliot d
>I was under the impression that such rod was so hard that you had to do something like what's in the next post; but it turns out that the rod is actually quite soft and can simply be cut with a hack saw. That's what I do.
>Drill rod comes softened but it is much tougher than cold roll and takes considerable effort to cut a 1" piece. I only use drill rod in larger sizes for tool rest posts and tool rests. I use the narrower stuff, (3/8 and 1/4" for tools). For boring bars and such use cold roll steel. You don't need drill rod for this.
Cutoff wheel or hacksaw.
Ray Thompson - Middletown, IN
Re: Note the difference between ...
Al Crandall (N.E. of Indy)
>Note the difference between "oil-hardened" and "oil-hardening". I am not aware of any O-1 drill rod which comes pre-hardened, but there may be some somewhere. Oil-hardening describes the quenching medium which you will use as opposed to air or water quenching. As purchased, most drill rod is soft enough to cut with a hacksaw or metal cutting bandsaw. In an unhardened state, it will be "tough", but not "hard".
Eric
>I stand corrected. I checked Enco's website ,where I purchased the rod and it is oil hardening, not pre hardened. Should I go thru th process of hardening it or it is stable enough to use as tool steel as is?
>What are you going to use it for? If your using it for a tool rest or tool post no hardening is necessary. If you want it for a tool rest you could try hardening it but you'll need a forge or something similar to harden a 12" piece. It's hard to get it evenly heated and you have to maintain that heat for a period of time. You can get the instructions on your specific metal from Enco.
If your using it for tools then you only need to harden the cutting edge.
Eric Knutsen
>I'm using it for a set of hollowing tools I plan to make. The drill rod will be inserted into the handles. I have HSS 10% cobalt square stock for the cutter tips which will be glued into the end of the drill rod. I'm assuming I'd need to harden the drill rod for this application?
Don't harden it.
Ray Thompson - Middletown,IN
>If you are just holding tool bits then use cold rolled steel or use the drill rod un-hardened. Hardening brings nothing to the table for this application. Also if you are working the steel with regular drills and such don't use a cutoff wheel, use a hacksaw instead. You can use a cutoff wheel when you are shaping with a grinder but it will harden the very end and make it difficult to work with regular tools.
Ray
Eric is right on. Don't harden it.
Brent English
Re: Eric is right on. Don't harden it.
Brent English
I meant RAY, not Eric
Brent English
That's OK, I answer to anybody..
>especially if there is food on the table.
Ray
