Canary in the mine?
Canary in the mine?
Canary in the mine?
Carole Valentine
>Ever since I put an OSB ceiling in my shop this spring, I have noticed that every bug I have seen in there is either dead or dying. What the heck is in that stuff? The original walls were OSB and I never saw bugs dying unless I stomped them or sprayed them. Is this new stuff on the ceiling out-gassing something that is going to make me keel over in there one night???
Re: Canary in the mine?
Chuck Engstrom
>Good question! The dying bugs would make me wonder too. If the imprinted side is still showing, or not painted over, see if you can get any info from the manufacturer. There's probably a date/batch code on it somewhere. How about OSHA, NPSC, FDA?
Keep us posted so we know you're still singing.
Best--
Chuck Engstrom
Walt Ahlgrim
>Most MDF is glued together with formaldehyde. You can get the material safety data sheet or MSD from the lumberyard.
The Chicken Little�s say the slightest breath of formaldehyde will leave you bed ridden for the rest of your now shorten life.
But at one time we thought it was ok to watch nuclear explosions as long as you had your dark goggles on.
Walta
Russ Fairfield
>An exterior Phenol Resorcinol glue that contains Formaldahyde. It kills bugs quite eddiciently, but the level is safe for humans and little kids. That is the same thing you smell in a brand new trailer house.
Carole Valentine
>Well, I like your reply, Russ, since there is nothing I can really do about it. Sure is saving me some money on the bug bombs I usually have to use (which aren't nearly as effective!)
>How long has the OSB been up? I would think it would out gas pretty quickly and approach "zero". After about thirty days 90% should be gone and after another 30, 90% of whats left should be gone and so on.
Had a friend who got in the business of installing Urea Formaldehyde Foam Insulation. Mixed wrong or poorly, it would outgas and bother people's eyes. (This was 30 years ago). Found out "eyes" were about twice as sensitive as the best detectors we had at the time. In bout ten days it depleted enough that it no longer bother them. Many people just thought "they got used to it". Wonder if it killed bugs?
Carole Valentine
>Can't remember when it was put up but it was back when the weather was still cold - Feb or March probably. I don't smell it anymore but it's still killing bugs.
eddiciently? Is that a word?
Terry Alexander
Ric Taylor
Re: eddiciently? Is that a word?
Ric Taylor
>It's a technical term that describes a method used by woodturners to kill bugs.
Ed Heuslein
>Yup! It's a synonym for efficiently!
Mike Stafford
Mike Stafford
>This OSB must be leftover from the batch that was used to construct the FEMA trailers that are killing the poor folks in Louisiana.....
Re: I had the same exact thought !!
Jamie Donaldson
Mike Nelson
>Carole, this may help explain your OSB(oriented strand board).."Some manufacturers add zinc borate, 2ZNO.303.3.5H20, a powder which is toxic to termites and molds and fungus but not mammals in applied doses." Hopefully us 'mammals' are OK!
