John Jordan Shear Scraper
Barry Turner
>Does anyone have this tool? Do you like it? I am asking about the tool that has right and left hand bevels on either end of a short blade that fits into a cast aluminum handle. Is it used off the toolrest or is it used freehand? Thanks.
Re: John Jordan Shear Scraper
I do! I do!
Jennifer@Indy.USA
>Barry I bought one earlier this summer and have come to love it. It puts a baby smooth finish on your work and helps tear out issues immensely. It's heavy duty and built like a tank. I highly recommend it.
Jen
Re: I do! I do!
Barry Turner
>I saw one at John's booth at AAW Louisville last year. It is well made, but I'm a bit confused about how it's used. Is it used off the toolrest or just freehand. I seem to remember John using it hand-held.
Re: I do! I do!
Barbara Gill, Remlik VA
>Me too; I really like mine.
Re: I do! I do!
Jennifer@Indy.USA
>I use the tool rest. I'm not sure what the advantage of using it off the rest would be? I've seen people use cabinet scrapers as shear scrapers free hand. I'm not a fan of that practice though. Seem a bit scary to me.
Jen
>Barry I have one. I find it fabulous for scraping green wood. I use it on the tool rest. I'm use my flat scraper off the tool rest and it's great for dry wood but John's beats it hand down for green wood. It also holds an edge longer than my flat scrapers and my homemade shear scrapers. You still have to hone it fairly often.
Re: I do! I do!
Barry Turner
>I don't know either, but I seem to remember seeing John Jordan use it that way in a demo. I try not to be too creative in technique. I have enough trouble with tried and true methods.
eliot d
>I have it and use it both on the tool rest and off, usually at a higher angle with the lathe turning not too fast, I find I can exert more control over it off the rest. It's a fabulous tool! I can't figure out why it works better than other tools designed to do the same thing, but I believe it does.
Re: I do! I do!
bowlman
>Ditto to what Jennifer said. Got mine awhile back, and although I can shear scrape with other tools, I really like John's version. Its always ahndy no matter what I'm turning.
Re:JJ's shear scraper is used....
Jamie Donaldson
>... with the rest as a support and angled up at about 45 degrees with a light touch. Works like a champ for me - anything that reduces sanding like this tool does is worth mucho money to me!
Doug Thompson near Cleveland
>John, it must be to early in the morning for me. Could you explain on the tool rest and off the tool rest. Is this flat on the rest and what angle? off the rest.
When Mark Goodall returns from Vacation the skews/scrapers will go on the web site.
>Doug I started using a 1/2" straight scraper years ago to do my hand mirrors. I was new at turning and the scraper just seemed to be awfully aggresive and would leave tear out. Not bad tear out and probably better than some I did with the turning tools, but still it wasn't that clean. I hadn't seen other turners turn and tried using a 45 degree angle with the tool on the tool rest. Must have done something wrong because I got one heck of a catch.
After playing around awhile I started using the scraper with the handle held really high, about 75 to 80 degrees, and would then move it so the angle that touched the wood was at a shear angle. Now I could take of the tiniest of shavings. Held this high there isn't any way to get a catch. I usually demonstrate this by holding the handle and touching the wood with the scraper. No matter what angle you put the tool it won't catch, the wood simply pushes it away.
I usually have my left hand on the tool rest and then gently push the steel into the wood with my fingers while holding I hold the handle almost straight up with my right hand.
The only downside to this method vs the tool rest method is that sometimes you can get chatter started and it will follow the chatter. When that happens I will go back to shear scraping with the tool on the tool rest.
This is not all that different from the way Clay Foster uses a cabinet scraper on the outside of a vessel. Slow the speed down and hold it at a shear angle, in this case well away from the tool rest.
Thanks John
Walt Ahlgrim
>I start on the tool rest flat get rid of any bumps, ridges and tool marks. Then on the tool rest at 45� work on any tear out. At some point the surface is smooth enough to come off the tool rest. It is time to hone the tool and go for a final surface off the tool rest at an steeper angel no need to be at the center line just find the spot that produces the best shavings. I love this tool, it is always close at hand.
Walta
