opinions please -- tool handles
GaryG in MD
>This is a completely subjective question, and one with commercial context, but I'm curious -- what is your favorite purchased tool handle, and why? Please answer for two cases -- price no object, and price a consideration. Thanks, Gary
Re: opinions please -- tool handles
Bob Moffett
Bob Moffett
>I like to make my own tool handles out of either maple or oak. I can get them to fit my hands better that way. Plus, it's a fun, quick project.
bowlman
>I have 2 of the Mike Hosaluk Handles. Saves a lot of weight to be able to carry two handles and a bunch of steels, rather than 1 handle per tool. This is my choice for "price is an object" as well as price not a limiting factor.
Dick Hines
Dick Hines
>I have 3 Keltons. I don't know if they are my favrite or not. They go with my hollowing bars. They are the only ones I have ever used so I am not a good judge of what is the best.
I never purchase tool handles
Brian Hahn in SW Wisconsin
>Why purchase a one-size-fits-all handle when you can make one that fits you?
I have yet to find a commercial handle is sized correctly for me. The thickness is a major issue - they are grossly under-sized for my hands. And most of them are way too short.
Jorge Castaneda
>Gary,
I make my own, loong hanles, medium handles short handles, that way, I have whatever I need for each project. The other win win thing about this is that I make them with set screw, so when I go to the grinder, is just the steel.
Life is good
Jorge
Steve Kubien
Making your own with a set screw
Steve Kubien
>Hi Jorge,
Could elaborate a little please? What do you use for the ferrule that is heavy enough to allow the screw to engage the threads properly? I am envisioning a chunk of aluminum or brass that is bored out to receive the tool and a couple of tapped holes on either side to grip it. Am I close? Deets! Gimme the deets!
Thanks,
Steve Kubien
Gerry Meekins
>Gary,
I have a couple of the Keltons and a Trent Bosch. The Keltons are more versital since you can reverse them for a different size shank. I guess that makes them more cost effective. On the other hand I like the Trent Bosch handle better because of the covering he uses. It's just more comfortable in my hands.
Hope that helps,
Gerry
Bob Stroman
>Gary,
I just became a Trent Bosch tools dealer after buying 4 of his handles and the reducing inserts. The 3 inserts fit inside each other reducing from 5/8" to 1/4" in one handle with stops at 1/2" and 3/8". The Bosch handles range from 12" to 24". The aluminum 12" is light and feels great on shorter tools particularly spindle gouges. The 20" handle feels better with steel shot in it, and the end is sealed to eliminate leakage.
I also have 12" and 17-1/2" Oneway handles. The Oneways are steel so they are heavier and fit certain situations very well. You really need to try different handles to determine which feels best to you in each turning situation. The metal handles are more compact for going to workshops, and they allow you to adjust the tool length.
Bob Stroman
Bob Moffett
Re: Making your own with a set screw
Bob Moffett
>Steve,
I also use the set screw ferrules on the handles I make. I get them from a guy named Al Basham out of Raleigh, N.C. for $20. You can get to his website by going to Google and typing in Al Basham. I am not affiliated with him or have any monetary interest with him. Also Packards sells Holaluk Tool Handle Inserts for $20. The ones from Packard are sized 3/8", 1/2" and 5/8". I don't think Al has the 5/8" size, but I know he has the 3/8" & 1/2" size.
>Steve Use Brass pipe nipples. You have to cut them up into Ferrule size pieces. Then I true them up on the lathe before putting them on the wood. They are quite thick and come in lengths up to 12". Then use a fine thread set screw like 1/4 x 28 or 10x32.
Steve Kubien
Well that makes sense! Thanks
Steve Kubien
Fog Tanner
>I just got through making two of them, one for my new skews and the other for 1/2" gouges. I used a piece of 1" copper water pipe (has 1 1/16" ID) 3/4" long. I turned the wood into a cylinder for the first 7-8" and fitted the copper pipe and pressed it on. I measured back 1/4" from the copper pipe and 1 13/16" from the end. I went to the drill press and drilled two 3/8" holes. Into these I screwed some 1/4-20 brass threaded inserts.
I remounted the handle and turned to completion, drilling a 1/2" hold for the gouge and 7/16" for the Thompson skews. A 1/2" shallow gouge and 1" skew shaped the brass with no problems. A couple of 1/2" long 1/4-20 set screws hold the skews in place and 3/8" long hold the gouges.
Brass threaded inserts came from Woodcraft, $3 something (under $4) for a package of 10. Set screws were 8 cents each from a machine supply, so my total cost was under a dollar for each handle. Beats the $20 for the ones in the catalog. I plan on making another tomorrow for my 5/8" gouge.
thanks
GaryG in MD
>I also like to make my own handles, but I'm short on time right now, and I just bought a pair of Doug Thompson gouges that I'd like to try out sooner rather than later. That's why I asked about "purchased" handles.
I always like to see the info about make-your-own handles too, because there are so many different ways to go about it, and it seems like I learn something new every time people discuss the topic.
Thanks to all, Gary
Mandles
Jorge Castaneda
>Steve,
Here is a quick shot, as you can see there is nothing to it, the ferrule is just a short lenght of galvanized pipe that was laying around, cut with a hack saw and filed flat while spining on the lathe. A shop made "V" block was used to support the ferrules for drilling, then drill and tap after installing it in the handle.
I made the handle and then drill the end, made a tennon slightly overzised so it is a compress fit, drill and tap and it is ready to go. the whole thing takes half an hour or less.
Have fun!
Jorge
drive by gloat: the gauges are Doug Thompson's... ;o)
oops! Handles
Jorge Castaneda
Doug Thompson near Cleveland
>I made a couple with set screws from 1-1/4 square solid aluminum, bored a hole to fit the tool and knocked off the corners on a lathe. All for the rip off price of 8 bucks a foot. The local metal mart is top dollar but it's close by.
Re: thanks
eliot d
>As you see , it's easy to make your own. but if as you say , you're in a hurry, the easiest thing to do is to purchase those brass adapters that have a couple of set screws in the side(Hosolic(sp?) sells them for $20.). Then, either make your own wooden handle and glue one of these in a hole in the end, or use the Hosilic or One- way handle. the main point of this kind of approach, vs. gluing the whole tool into a wooden handle, is that you can take the tools in and out as needed.
I had a lot of fun making several of the Hosolic-type adapters from mild steel so that I could use a small, e.g. 3/8" tool, in my Stewart arm brace, which has a 3/4" tenon. I liked making these little adapters so much that I am thinking about getting a small metal lathe to do other similar stuff.
RonZ
>I try and make my own.
Re: thanks
GaryG in MD
>Your point is well taken, Eliot -- it's nice to be able to move various tools in and out of different wooden handles. I like that approach. Thanks for the thought. ...Gary
Don Orr
>Price no object goes to Crown Pro PM or Oneway (totally different materials). Economy tools goes to Craft Suplies USA Artisan brand-made by Henry Taylor-nice and long. I do prefer to make many of my own though.
