Walnut vase
Walnut vase
Walnut vase
>Here is the walnut hollow vessel that I saved. I cut through the top while trying to make it thin. I cut the top away and finished thinning it out to the bottom. I didn't like the way it looked so I pierced the top using a dremel. That was a pain. Although you can pierce with the dremel it is slow and you really have trouble controlling the cut. I would highly recommend using the dental type high speed grinders if your going to do this. For the occasional piece the dremel will work. I cut about 6 to 10 holes and then took a break because one miscut and you have potentiallly ruined it.
I also have one of the HF 56K air grinders and it has more power but the cut is still hard to control and it eats up air like it's going out of style. I will probably restrict it's use to hogging off wood, it might fit inbetween the dremel and fordem in power and handling.
Re: Walnut vase
Re: Walnut vase
Jennifer@Indy.USA
>Oooooo....I like this one A LOT John. The figure in the walnut is wonderfully positioned. Great rim treatment with the piercing too. Very nice piece.
Jen :)
Re: Walnut vase
Re: Walnut vase
Allen Neighbors
>John, you amaze me with the things you produce! Terrific save on this one! You have to have some mighty steady hands to make a piece that thin... and also to do that piercing. Gorgeous piece!
What you say about the Dremel one of the main reasons I don't try piercing... the other one is the lack of steady hands.
Re: Walnut vase
Andy DiPietro
Re: Walnut vase
Andy DiPietro
>Beautiful piece John, What are the dimensions? The rim looks real thin. I would like to see the back of the form. It looks like there are some light shades. I really like the range of colors you can get in walnut.
Andy DiPietro
Re: Walnut vase
Re: Walnut vase
Mike Rubes, Apex, NC
>Hi John,
What a wonderful piece (and a great save!) I like the piercing, as it really stands out and is neat, but the grain orientation is right on. The symmetry is striking.
Thanks for the pic, great stuff.
Mike
Hoping to turn this afternoon in Apex, NC!
Re: Walnut vase
Mike Stafford
Re: Walnut vase
Mike Stafford
>That is a most fortuitous save and beautiful too. I am not sure I like people who can mess up better than I can do on purpose.
Really nice work, John!
Re: Walnut vase
You must have been a ...
Ed Moore
>soccer goalkeeper! Nice save!
I like this piece.
Ed
Re: Walnut vase
Re: Walnut vase
>Andi it's about 8" tall 4 1/2 to 5" wide and 2mm thick most of the way down. I let it get thicker at the bottom so it would be more stable. It starts to thicken out to 4mm from about 1" of the bottom and then I left it about 1/2.
There is some light colored wood on the other side. I did take a photo and will try to download it later. I have to go shoot all the Chemical Engineering instructors and their labs this afternoon so I may not get to it until very late today or tomorrowl.
Re: Walnut vase
Re: You must have been a ...
Donna Banfield
>Stunning somehow doesn't seem to say enough. This pierced hollow form and the solid walnut hollow form (posted further above) are ...WOW!
And you wouldn't know about the fingerprints on the top of the solid hollow form unless you pointed them out. At least, I didn't see them!
Re: Walnut vase
I really like this piece, John. Great Save!
Ruth Niles
Re: Walnut vase
Re:OUTSTANDING!!! Or should I.....
Jamie Donaldson
>... say UPSTANDING! Anyway, it's EXCELLENT John!
Re: Walnut vase
Re: Walnut vase
RonZ
>Excellent job, your save turned out to be a design opportunity. I like how the piercing you did flows like lace instead of random holes.
Re: Walnut vase
Re: Walnut vase
George Van
>A very talented save John, I wish I were that creative.
Re: Walnut vase
Re: Walnut vase
Wayne Allen, Carson City, NV
>John-- This is a beautiful piece. My compliments on the shape, grain orientation and the piercing. I tried some piercing with one of those high speed drills and the edges of the cuts always seem to be burned black. It looks like your use of the dremmel tool does not burn the edges of the holes so maybe you did use the right tool.
Re: Walnut vase
Re: Walnut vase
>Wayne That's one of the tradeoffs. The slower speed tools don't burn the edge but leave a slight burred edge so you have to either take a really light pass around the outside of the hole to remove this burr or go back with sandpaper and possibly a jewelers file to clean them up. this is time consuming. It's also very hard to control the cut accurately.
The high speed grinders cut clean holes but as you noticed burn the edge. This can be good or bad depending on what you to the outside and inside of the piece. They are very easy to control the accuracy of the cut but the wood needs to be really thin, probably 3mm or less and the thinner the better. I have a friend coming in next week who does a lot of piercing and I'll ask him his opinion on this.
Re: Walnut vase
Re: Walnut vase
>John -- Thanks for the info. I would indeed be interested in hearing more on this piercing subject. Looking forward to hearing you and your friends thoughts on this topic.
