My lathe is back in operation - at last!
Andi Wolfe
>The three-phase inverter on my Stubby 750 lathe died the week before the Utah symposium - just as I had a small block of time to work on some stuff for the instant galleries. Ouch! I purchased the retrofit kit from StubbyLathe USA at the AAW symposium. The kit arrived to my house before I returned home from my travels. I finally had a couple of evenings to work on it and I finished the retrofit this evening with some assistance from hubby. I am sooooooo happy to have my lathe up and running again. I've been going through severe withdrawal. . .
The good news is that putting the retrofit electronics onto the lathe is pretty straightforward - easy enough that even this mechanically-noninclined person can tackle the job. The hardest part for me was attaching a metal plate to the stand on which to mount the new inverter. I used self-tapping metal screws, drilled in with an impact driver. I drilled pilot holes first, but the effort to put in the metal screws was still pretty hard on me. My arms and shoulders are looking forward to a visit with my massage therapist on Friday ;-)
Andi
Re: My lathe is back in operation - at last!
Jennifer@Indy.USA
>Andi, so glad to hear you're up and running again. What a bummer that must have been. How was the Utah symposium? It's one I'd like to get to sometime.
Jen
Keith Tompkins
keith tompkins
>HI Andi, that's one of my biggest fears...the electronics on my lathe would give out at the worst possible time! Glad you got it up and running again!
Keith Tompkins
keith tompkins
>Hey Jen....happy birthday! a bit late.... :)
:)....thanks!
Jennifer@Indy.USA
tm
>Welcome back to the toolrest. Last winter I was forced into a hiatus
due to some shop improvements. It sure was a nice feeling to see the
curls fly again. Turn with a vengance became my personal mantra.
tm
RonZ
>When I left computer engineering and decided to turn full time I thought my computer worries were over, little did I know....
My Vicmarc VL100 controller went after two years of heavy use. The new inverter was half the size of the original and had different wiring and programming sequence. I had to bribe the techniciam with turned goods to get it up and running for me. I still have problems with my VL300 controller. One out of 100 startups it goes reverse and then forward. I lost a good piece that way.
You should keep a supply of bowls to be embellished so you can do something while waiting for your lathe to get fixed. =o)
Andi Wolfe
>Jen - Utah was a blast as usual. I'm still working on photo processing, but will have a blog post pretty soon.
Andi Wolfe
>Ron - that was the problem. I was at the end of my stock of bowl blanks for surface or carving embellishments. I had blocked two days for the lathe and then all those plans went astray. . . Guess I'll try to not let that happen again.
that's why I like the old lathes
>Glad your back in business. I worry about that also. Back when I started you could replace or build virtually every part on the lathe. You could buy the bearings at your local bearing store and replace belts or swap motors.
Even when I upgraded to a DC motor and the controller broke I was able to go to radio shack and hack together a bridge network and run the lathe on one speed. Fortunately I still had the step pulley.
It will be much harder to jury rig 3 phase power. I've thought about keeping keeping a spare motor around to use to create the 3rd phase if needed.
Re: that's why I like the old lathes
RonZ
>I agree but unfortunatly I got used to having and relying on variable speed. I got out of the problem two ways. One way is by having three lathes [VL300, VL100, and a Jet I teach on] with one Wivamac on the way I now have a redundacy solution [I once was an engineer before lathing]. The other way is I am the importer for Vicmarc in Israel so I keep spare parts for customers.
Stan Townsend
>Ron do you have a conection to deal with Wivamac? I have a 1000 and my importer got seriously ill and cannot service me. You can answer on WC or my E-mail Thanks Stan
