Veritas - Innovation in Tools
I listened to you, and now ...
Ed Moore
>I've got a new Hunter #3 tool. The next step is for me to learn how to use it. As I looked at the tools at Woodcraft in Roanoke, the #4 didn't look that much bigger than the #3. Why not get the #4 instead?
So, here is my basic question, posed to those who have both Hunters, #3 and #4:
Is the #3 better for boxes and goblets, or is the #4 just as good?
Thanks,
Ed
Re: I listened to you, and now ...
C.W.Stivison
>I bought a # 3 and I would like to know also.
CW
>If I were only buying one it would be a tough decision. Except for really small boxes I think both would do the same job. The #4 is better for deep hollowing because the shank of the tool is bigger, not because the actual cutter is bigger.
I like the #3 because it was easy to adapt it to a 3/4" bar by drilling a 3/8" hole in the 3/4"shaft and putting a couple of set screws in. I think I will use this a great deal hollowing vesssels up to 10" I can use this in my arm brace or in my captured bar system.
I'll probably use the #4 for boxes and small vases since I mounted it in a wooden handle. I have currently mounted the #1 in a 1/" bar and so far have only used it for smaller vessels but hopefully will have time to do a large vessel with it. I plan to mount it in a 3/4" bar and use it like I use the John Jordan hollowing tools. I think this will be better for deep hollowing through a small hole but won't know for sure until I have time to try it out.
And I am glad that I ...
Ed Moore
>did. I just tested several tools of a similar nature on a piece of maple and the Hunter #3 was the easiest to use and gave a very smooth cut. It MAY be that a hook or ring tool, used expertly, can remove stock quicker than a Hunter. Yet, none of these tools do as good a job with the center point as does a scraper. And, I readily admit that with more practice these tools might do almost as well.
So, after a fifteen minute test drive, the conclusion is that the Hunter tool is worth the price and should provide a lot of satisfaction when hollowing small boxes and some ornaments. I'm looking forward to using this tool.
Thanks,
Ed
