>I have two of the Strongholds, same as the Talon except larger. I have to clean mine with compressed air every so often. When I do I usually spray them with some Teflon all over the gear sets. I have not had any problems with them collecting dust from that. The Teflon is a dry film lube that I use on a lot of my woodworking tools with no incident. I turn both dry and wet woods and just keep my chucks clean - used to be on a daily basis, but I found weekly was good enough. Also if you have two (or more) chucks, then when one sticks you move on to the next one.
>I used to have to clean mine, too often. This is why I sold it and got the Vicmarc chucks. Its closed in the back. I have about eight of them and I haven't had to clean them yet and its been about four years.
Re: Oneway Talon chuck is sticking... does anyone *LINK*
Rick Allen
>The link below is to a PDF of the Oneway Talon Chuck instructions. You will find on page 11 Oneway's recommendation for curing a sticky chuck.
"If it is sticky, soak in varsol or mineral spirits with about 10% oil added. Allow to sit for 1/2 hour or more, and blow clean."
You can also disassemble the chuck, inspect, soak, clean and reassemble.
Blowing out the chuck on a regular schedule is always a good idea.
When you inspect the disassembled chuck you may find a little "gunk" on the jaw slides. A little mineral spirits and an old tooth brush (or an acid brush) will make quick work of the "gunk".
A few years ago Dick Sing did a segment on the DVD woodworking magazine, "Woodworking at Home" where he showed you how to inspect and tune up a chuck. The process Dick showed included filing or sanding some of the surfaces to insure reliable use of the chuck. Maintenance is part of owning and using a chuck. BTW the magazine folded a while back.
I periodically disassemble my chucks and clean them with WD-40 and a tooth brush. When they are put back together, they are as good as new. Chucks are not maintenance-free, they do require some attention from time to time.
>I have also gone the Vicmarc route. I have too many jaw sets for the Strongholds to sell mine at this point. But, I have two Vics and am adding jaw sets for those only (picked up two more sets while at Craft Supplies week before last). I plan on getting a couple of more Vicmarcs, both the large and small version within the next year.
I likewise have not had any problems with the dust getting in my Vics and have not had to disassemble them yet. If its every four or five years then I can live with that.
>This probably is not the problem with your chuck, but I mention it due to recent experience. I bought a used chuck from a gentleman and the jaws were difficult to work. Thinking it needed a good cleaning, I disassembled it only to find the chuck had been seriously overstressed, enough to prematurely wear the internal gears and enough to warp the body causing the jaws to bind. A few hours of rework and the chuck works smoothly again.
The owner evidently had eaten his Wheaties and didn't know his own strength. The moral of the story: if cleaning and lubrication doesn't work, check for overstressing. (This was a Supernova II, perhaps weaker than the Oneway)
>"Thinking it needed a good cleaning, I disassembled it only to find the chuck had been seriously overstressed, enough to prematurely wear the internal gears and enough to warp the body causing the jaws to bind. A few hours of rework and the chuck works smoothly again."
What did you do to "rework" the chuck? I have a Talon chuck that has one tight spot, it works smooth to a point, then hard to turn for about 4 rotations of the key, then smooth again. Cleaning helps a little but not for long and now you have me wondering if my chuck is stressed. I do ask a lot of it.
The first thing I did was determine the problem. After disassembling the chuck completely (removing the back, circlip and gears) and cleaning/lubricating, I tried sliding each jaw by hand. This indicated definite binding in the slots. Holding the chuck body so light glanced off the front, I noticed some distortion in the face of the body on either side of the slots. This told me the chuck had been overstressed. (Severely, since that steel is THICK!)
Digital calipers indicated almost a near zero clearance at points inside the slot which was causing the binding.
To repair, I first flattened the top using a wide, fine diamond stone. (Probably unnecessary but it made me feel better.) I used a small straight edge to check the inside of the slots for high spots, then used a jeweler's file to knock these down. I used diamond-faced paddles (the same I use to touch up my turning tools between sharpenings) to carefully flatten the insides faces of the slots until each jaw slid easily. I did not want to remove too much metal and introduce slop. Re-cleaned/lubed/assembled and put it to use!
BTW, the Supernova II uses the same pinion gear as on the chuck key for the older Supernova but embedded into the chuck body. On this chuck, the pinion gear teeth were severely worn from the abuse. I plan on replacing them at some point if I can get them cheap enough, but if not they still work OK except for some extra backlash. I reserve this chuck for lighter duty.
BTBTW, this chuck also worked OK near the center, then got harder (and almost impossible) to turn toward the outside. Your's sounds less severe so if it has the same problem, it should be easier to touch up.
>It seems that someone needs a lesson in the use and abuse of a chuck.
The lesson here is that the chuck is intended to hold a piece of wood in the lathe, it is not a wood crusher.
Three things happen when the wood is crushed by the chuck jaws. The first is that crushing the wood past the starting point of the deformation does nothing to increase the grip on the wood. When the wood starts to move, that's as good as it gets. Using a piece of pipe to get more power does nothing other than crush the wood farther and accentuate the problems. If we need more holding power than we can get from the wrench, we should either be using a faceplate, a waste-block from harder wood, or looking for a more solid piece of wood.
The 2nd is that crushed wood has less strength than solid wood. Crushing the wood under the chuck jaws can actually reduce the gripping power of the jaws.
The 3rd thing that happens is that the wood does not crush equally in all directions. The end grain doesn't crush as much as the side-grain. The result is that the wood will move out of being concentric with the lathe. Most people immediately blame the chuck for this "runout", when indeed it is their own heavy hand that is the cause of the bouncing bowl.
The moral of this story is to not use a 2' piece of pipe on the wrench to get a better bite on the wood. A damaged chuck can be the result. I have seen these chucks with bent teeth on the back of the scroll from too much forse, chunks broken out of the scroll, and twisted and deformed chuck wrenches. All were from using a piece of pipe to get more grip on a piece of wood.
The last time I checked, Oneway did use a better grade of steel with a higher elastic limit than the steel in a Nova. But, everything has its limit, even the Oneway Talon will bend and permanently deform when enough force is applied to it. The only difference is the amount of force required to cause the damage.
