PM3520 Rocking Headstock - Update
Jerry Hall
>A while back I asked for help on a 1/64th or so, fore and aft rocking of my headstock. It was particularly noticeable with large wet blanks. I got a lot of good ideas, and some confirmation that a few others had had a similar problem. I cleaned under my ways, and put a longer handle on the cam lever and thought I had solved my problem for a while. Not. It was better, but my feeler gauge at .005 moved easily under the drive end, even when well locked down. So today I bit the bullet and removed the headstock. There were shiny spots under the camshaft, and my straight edge clearly indicated a a high point on each side, and also around the set screw. I covered the center of the base around the camshaft with a black sharpy, made a lapping block of mdf and 220 grit PSA paper and lapped away, being careful not to touch the fore and aft surfaces. Washed off the sandpaper regularly. My straight edge showed I was making progress, but slowly. So on one side I used a very fine mill file, carefully, checking often and finished up with my 22O. Reinstalled the headstock and turned a fairly heavy round with no problems.
But I still have a concern. How did it get that way? I note there is less than 1/4" of iron casting under the bored out eccentric shaft at the thin point. Could my heavy blanks be distorting the casting? I hate to think the Mustard Monster can't handle repeated heavy blanks. For now I am assuming the machining of the holes caused "green" iron casting to create the high spots and that it was not milled flat afterward.
Re: PM3520 Rocking Headstock - Update
Jerry Hall
>I also ground round the corners of the locking plate under the ways, and I have much less problem with the headstock hanging up on the ribs as I slide it along. You 3520B owners have a nice round plate.
Here also is a picture of my "tool" handle that I added to the locking lever. It is much handier.
Gary in Zirconia, NC
>Jerry,
Thanks so much for the update. You did a great job. That is what I thought was wrong with mine. But instead of going through the fix you did, I sold mine.
Rick Allen
>Please note that there were some early PM3520A lathes sold which had a cast locking plate to the headstock. When excessive locking pressure was applied to secure the headstock the cast plate could crack. The same appears to have been true for the tailstock on these early PM3520A lathes.
Ed Larson
>Glad to hear that you found the problem. See you next Wednesday. Is this a show and tell item??
Jerry Hall
>I will be bringing Dana as my show and tell item. He was my technical consultant and muscle. That #!@&^ headstock is one heavy and awkward item. Setting my workmate table next to the lathe worked well and made it doable for two old guys who keep their legs well under the weight, but keep their toes hidden under the workmate, just in case!
Jorge Castaneda
>Hi Gary,
What you got instead?
I like spinning big chunks of wood too, and I am saving for the PM3520b,
so if there is a problem with this machine maybe I should start thinking of something else.
Thanks in advance
Jorge
>I really liked my PM3520a, but the rocking headstock was the reason I sold it. Also, the banjo and tool rest weren't as solid as I'd like. I still think it's the best lathe for the money.
I bought a Oneway 2436. I think it's the best lathe.
nothing is more important.....
TDaniel
>than a toolrest that will move easily and stay where you lock it. I agree Gary, the One-way is far superior to the PM's for exactly the reasons you stated. I cured my Vicmarc VL300 of the banjo and toolrest locking problem by replacing them with One-way banjo and toolrest.....what a difference! Ok, the lathe is blue and the banjo and toolrest are white....so what....it works now. By the way, I did discuss the problem with Vicmarc before going the One-way route but they insisted it wasn't a problem.
