drive center and live center
Bill Harmon
>I have an old craftsman lathe I got for nothing. Unfortunately it is missing the drive center and and live center. It is a 3/4x16 thread spindle but it is not hollow. Ther tail stock is 1/2x20 thread. If anyone knows where I might find these items I would be most grateful. I am open to any and all sugestions.
Re: drive center and live center
tm
>You might try packardwoodworks.com or www.woodturnerscatalog.com
Rob Wallace
Re: drive center and live center *LINK*
Rob Wallace
>Bill:
Penn State Industries (link below) has a bunch of 3/4-16 accessories for your "taperless" headstock spindle. It would be possible to buy a scroll chuck that will fit your lathe spindle and then use a 'chuck-adaptor' type spur drive or Steb center with it to drive spindles if that's what you need to do. Obviously the chuck would be useful for bowl, etc. turning on its own.
As for the tailstock end, the 1/2" threaded fitting is a mystery...must have been a special 'Crapsman' designed live center. You might be able to get a machinist to turn down and thread the Morse taper of a standard live center to 1/2-20, and then use a 1/2-20 coupling (like those for all-thread) and jam nuts to marry it to the tailstock threaded part. You might also keep an eye on eBay to see if you can find accessories that were from this lathe model or vintage.
From your explanation, and without actually seeing the situation, this is what came to mind if I were in your shoes. Since you didn't pay for anything (...yet!), the cost of some machining and a few lathe accessories might get you spinning soon.
Good luck with your new toy...
Rob
adrien Coblentz
>Or try Sears for parts"?
