Veritas - Innovation in Tools
first lathe
first lathe
first lathe
greg stahl
>I'm looking to buy my first lathe. I have the following Delta X5 machines in my shop: planer, table saw, drill press, band saw, joiner and a Craftsman radial arm saw and a Porter Cable miter saw; along with a Oneida cyclone system for dust control. To me it seems expensive to by the X5 lathe, but I'm a complete novice and just starting this hobby. Price is not a consideration, just something that I can grow into. tx
Re: first lathe
Re: first lathe
TDaniel
>If price is no object I would without reservation recommend One-way 16-42 with outboard attachment. You will never regret buying it.
Re: first lathe
Bob Moffett
Re: first lathe
Bob Moffett
>There is a Nova 3000 lathe in the classified adds that would be an excellent lathe. I have a Nova DVR (differnet from the Nova 3000) and have been very pleased with it. I don't have any affiliation with the person who posted the ad or any financial interest, it just looked like a good buy to me and I like my Nova DVR.
Re: first lathe
Re: What TD Said!! :)
Allen Neighbors
>(only it's a 1640, instead of 42) I have a 2hp Oneway 1640 with the outboard extension. Absolutely no gripes.
Re: first lathe
Re: first lathe
Jim Swank
>Price is always an object, even if not an obstacle. A gently used Nova 3000 is a good buy. The Oneway 1640 TD suggests is an excellent lathe, but a lot more money. In between the two, there's the Powermatic 3520b (TD doesn't like the banjo). Any of them offer a lot of bang for the buck, but the amount of bucks differ greatly. Don't forget to set aside $500-$1000 for tools, chucks, etc. Even if you don't plan on that much to start with, you'll still spend it or more in the first year if you keep the lathe.
Re: first lathe
Re: first lathe
Ralph
>As Jim noted, set aside more $$$ for tools.
I had a fairly complete wood shop BT (Before Turning), BS, TS, Drill Press, Jointer, Planner, routers, etc
Then I got a midi-lathe for a present... I quickly had more in the tools, accessories and such then I did in the lathe. And about as quickly out grew the midi-lathe.
So I got a bigger lathe, and learned to help with my desire to get better I would need more tools, chucks, jigs, etc. I suspect I still have more in "stuff", then in the lathe, and the lathe cost for 42000.
Of course I also got a 12' disc sander and thickness sander to help with segmented turning(oh the slippery slope).
Unless you know all you will turn will be small items, don't get a small lathe.
Unless you know you are going to really be turning huge stuff, don't get a huge lathe.
A Teknatool 1624 (the replacement for the Nova 3000) got marks from FineWoodWorking for best value. With a single bed extension it would be a "16-40", at less then the Oneway 1640 (but with lower power, lighter weight, etc)
Re: first lathe
Re: first lathe
Bart Rhoads
>Ralph I sure hope that was a typo on the price of the lathe. $42000?
And a 12' (foot) disc sander is a very large sander. Just kidding
Re: first lathe
Look Before You Jump
>Greg,
There are many fine machines available to separate you from your money. You can get a lathe costing from $300 to $8,000, but the cost will not help you decide if this spinning wood thing is you're Thing. The only thing that will do that is?
Right, you guessed it . . . Turning.
Therefore, before you start shoveling scheckles out the door, I strongly suggest that you invest in some lessons, preferably with the opportunity to turn on different machines doing different kinds of turning. You may find that spindles is your cup of tea, so a machine focused on bowl production would be a waste of money for you. The opposit is also true.
If, for instance, you have a Woodcraft store near you, check to see if they have turning classes available. A crafts school with a woodturning class is also great. The lessons will make it easier for you to get started without as many setbacks in gaining a skillset.
Many here will tell you that they've gone through several lathes before springing for the heavy metal they now use. Along the way they were able to build their skills, and therefore appreciate the next step and the better machine they moved into. I started on a $400 JET 1236. Took me about 6 months to outgrow it and another 6 months to decide on which big iron I was going for after I went from shop-to-shop trying out other guys' machines.
In short, turn a bunch of wood before you make an investment in a high-end machine. A cheaper lathe will catch dust just as well as an expensive one in case you don't take to this stuff. You'll also find that a less expensive lathe will be pretty easy to sell to another beginner.
Just my opinion, YMMV |;-}
mm
Re: first lathe
Re: Look Before You Jump
>I have to agree with Mark. I've had the Nova 3000, upgraded to the Powermatic 3520A, and I certainly think Oneway makes a heck of a lathe. Robust also makes a very good 16" lathe that has options to allow you to turn much larger.
You will want a good grinder, several tools and probably a chuck. The best way to decide on those is to take a class or attend some club meetings and get good information from other turners. Of course Woodcentral people will always help.
Re: first lathe
Re: first lathe
Ralph
>Up, note the $/4 relationship
