Turned Lamp Base
Turned Lamp Base
Turned Lamp Base
Michael Foster
>Just wondering if anyone has turned a lamp from solid wood and how they accomplished it. My wife would like a pair of lamp on the scale of some broken (and repaired) pottery lamps we now have. They are about 14" diam and 18 in high. My thought is to turn some nice wood, perhaps ambrosia maple, with the pith on center, hollow out from the base to about 1-2" walls to remove the pith. Let this dry, then re-turn it to true it up and make a plug for the base.
I would appreciate any advice from others who have made a lamp, or know of techniques used by others.
Re: Turned Lamp Base
>You might get buy with it on Maple if you dry it really slow but anytime you leave the pith in something that thick you risk getting cracks, even if it's just in the pith area itself. You are correct in needing to hollow the base out. seal it good after you rough turn it, especially all end grain areas.
I've always made my lamps from 2 pieces. A base and a stem. This way you can turn the base from side grain wood and not include the pith.
If you still want to try it here's what I'd do. Mount the lamp between centers with the pith dead center. True up the ends and then rough turn the lamp. Now drill out the pith. I would start on the drill press and drill as deep as I could on one end. Then put a board on the drill press and clamp it down. Drill the same size hole in this board and put a short dowel in it. Now flip the lamp over and drill into the other end. This will align the two holes. Then you can connect them with a longer drill in a hand drill.
Usually I drill a 3/8" hole all the way through using a lamp auger on the lathe but when turning a green lamp that will probably be 3 or 4 " in diameter I would drill the hole as big as I could and then plug it later. Drilling the pith out relieves a lot of drying stress and lessens the chance of cracking.
You've go my interest up and I have some Cherry logs that are bad about splitting anyway. I may just rough one out, drill out the pith, seal it and toss it in the corner and see what happens.
Oh by the way, I would hollow the bottom while it's still mounted between centers and just cut out the cone left by the tailstock when your done. Since it's endgrain you'll be hollowing from the center out so it should be easy to do while still mounted.
Mike Nelson
>Michael, I've made 16" vases from Ash and Cedar-elm using a 1 3/8" Forstner bit. I use the bit on a tail-stock chuck, go slow and after you reach the max of the bit, add an extension to go deeper. I am going to try an electricians bit (auger) they are strong and long enough to do an 18" lamp. And the large hole makes it a lot easier to hollow! Good luck, Mike
Jimiles-Charlotte, NC
>Have you thought of cutting logs up into "staves"
and doing a staved construction lamp? A little more work, but it does eliminate drying & hollowing problems. Set table saw for 15 degrees get some scrap 2 x 4s and try a prototype. Good luck!
Dennis Daudelin
>Doing it in segments also gets away from dealing with wet wood and drying.
I made this one last year for the house. I chose a ginger jar shape but you can make anything you like!
Sorry about the dark picture! You never have a good light around when you need it :-)
It was fun to make and the best part is that you don't have to cut the inside so it's wicked fast to turn!! I drilled a hole into the solid wood base from the side and ran the wire through there before adding the last (top) solid piece.
On this one, the top and bottom are walnut, the body is cherry and the feature ring is made of maple and bloodwood.
Using the 30 day trial version of one of the popular segmented software packages would be a good start!!
Dennis
Michael Foster
>I've done a lot of segmented work, including staved work. I considered a segmented lamp but thought the challenge of working a solid piece of wood might be fun and my wife thought that would look nicer. My thought with using a whole log is that removing the pith and hollowing to a consistent thickness may result in a piece that contracts, yet avoids splitting since the pith is gone.
Guess I'll just have to experiment, the biggest challenge I see is finding a way to chuck it up once the log is hollowed out.
