Chop Sticks
Ken George
>My daughter has asked me if I could turn a set of chop sticks for her. Has anyone ever made chop sticks? If so what wood did you use? And any suggestions for making them would be appreciated.
Thanks,
Ken
Chop Sticks
Ken George
Thanks,
Ken
Re: Chop Sticks
Eddie Pacheco, San Jose, Ca.
>I don't have any advice on how to make these, but here are some examples. The black one is ebonied and has some shell inlay. It's squarish (there's a word for you) with radiused corners. The middle one is round, 9 3/16", and of an open grained material. It may even be bamboo. The bottom pair are common from most local Chinese take-outs in my area. They look like they are maple as the wood is close grained.
The grid on the paper is 1/4" and I hope this helps you out until the pros chime in.
Re: I made some years ago, and .....
Jamie Donaldson
>...we still use them regularly. The woods were Brazilian Rosewood, Kingwood, Padauk, hard maple, and my favorites are the rosewood. I used the lathe to spin a sanding disc for shaping- no turning in the process.
Re: Chop Sticks
Lan Brady
>Ken,
I just returned from spending 28 days in China. I finally learned to use chop sticks. The guys over there like the ones made from Bamboo. But, Their bamboo is not what we see here. It is a thicker body.
In the stores, I saw many sets made from a maple type wood. The salemen always said, "Good Wood, No splinters".
THe restaurants use hard plastic chop sticks, but they do not grip food very well. I guess they clean better!
Good Luck, Lan
I did also. Started as table legs, ended as chopst
Belt sander
Dave Staeheli
>I've tried to make chopsticks on lathe. The only process that worked took too long. I met a guy who used to make them for craft shows, he made hundreds and hundreds, sold for over $25 a pair with many laminations. His favorite wood for the shaft was sandelwood. He laminated them up, then cut them rough on table saw, then used belt sander to shape. His final belt was 600 grit, which I have never found in a sanding belt! He had a source for them though.
Re: Belt sander
>Yeah, it seems like the belt or disk sanding method is a good process to make them alright.
Re: Belt sander
Ken George
>Thanks for the input everyone. I'll let you know how it turns(sands) out.
Ken
Re: Chop Sticks *LINK*
Darrell Feltmate
>Sorry I have no pictures but I have turned a couple hundred of these over the years. One of the potters here really likes them for her rice bowls so I need to turn some when I get the chance. I will take some pics and get a page up about them. Meantime, I have turned them between centers but they easier with the handle in a chuck. Start with a piece about 3/8" square and 10 1/2" long for eating sticks, longer for cooking. Turn to a little less than 3/8" at handle to less than 1/8" at tip with an even taper. Part off with a skew to about 10". I sand to 300 on the lathe and finish with a mineral oil/vegetable oil mix. Hope it helps.
Around the Woods
Re: Chop Sticks
Ken George
>Thanks for the suggestions Darrell, I will give it a try.
Re: Chop Sticks
Gordon Seto
>If the chopsticks are for actual usage, don't turn the whole thing round. Leave the top section square, you don't want them to roll around on the table.
TRADITIONALLY, better chopsticks were made from ivory, precious metal. Wooden chopsticks were not highly regarded. Those made from bamboo were for cooking. In reality, the bamboo chopsticks are the most user friendly. You can just throw them in dishwasher and they last. With the ivory, they are challenging on slippery food even if you are already master in using chopsticks.
Gordon
