Is it just me or..
Is it just me or..
Is it just me or..
Eddie Pacheco, San Jose, Ca.
>Have other PM 3520 lathe users inadverdently pressed against the spindle lock button while turning? I've turned 3 small pieces on my,new to me, 3520 (not A type) lathe and on each one I tapped the lock button with my arm while turning and the racket startled me each time. Is this part of the learning curve with this lathe? Maybe my stance is wrong?
I haven't turned any large pieces yet as I'm still learning to get the feel for this machine. Stepping up from my old Atlas 3/4hp lathe to this has been a real eye opener when it comes to cathes. The old lathe would stop. This one doesn't.
So far, I like this lathe a lot and now I see the justification for longer handles on lathe tools. Hmmm, that also means more money out of pocket....sigh.
Re: Is it just me or..
Randy Johnson Connersville, IN
>I've never done that but I've tried turning it off with the knob on the belt access door a couple of times.
Rick Davenport
>That's never happened to me.
The steel flange on either side of the button should prevent such an occurence.
It seems to me, you have to lean in a very specific spot.
To paraphrase one of my heroes - Henny Youngman - and to be a smart aleck too:
"If it hurts when you do that, then don't do that!"
Rick
Its just you...maybe
Brodie Brickey
>Ed,
I've had my model 'A' for 3 years now and never done that. On the A is has brackets around the lock also. It sounds like you're spending a lot of time in the 'line of fire' also.
As for the longer handle issue, buy one large handle or make one from a piece of pipe packed with sand or lead shot and wrapped with a comfortable tape. Put a coupling on one end to fit your 1/2" gouges with 2 set screws and the other side another smaller coupling. Then just buy the 'unhandled' gouges. You can change out as needed to your hearts content. You can also unhandle your current gouges to get more length.
The added bonus is when you sharpen the gouge, there's no handle to get in the way of your 'turning muscle' aka gut. ;)
Regards,
Brodie
Could be me and,
>The fact that my lathe doesn't have the shroud around the spindle lock button. Yes, I may have been in the line of fire. I think on the 3 times my arm pressed the button I was positioned right in front of the workpiece and angled to my left a bit. I was holding the tool handle with my right hand and my left hand was securing the tool on the tool rest. My left arm sort of nested in that recess that the headstock has on the corner.
I'll get a shroud for the lock button.
Thanks for the tip on the handle construction.
Re: Could be me and,
Brodie Brickey
>Eddie,
Sorry, my humor may have gotten away from me. I didn't realize the 'B' model did away with the shroud/brackets. Looking at it from the picture I can see how you might encounter problems when working close to the foot.
Brodie
That's not a B
Rick Davenport
>It must be a pre - A ?
And I can sure see how you could lock it up with a well placed lean.
R
jim
>I can't say if it's you or not. I've got the same model now for a year and a half and I've never had that problem ...........maybe I've got to work my way up to it?
>Eddie I just looked at my "A" and the lock has an extra plate that yours doesn't. It is screw into the same holes. It's u shaped so it acts as a guard to keep you from pushing the button accidentally. I can probably send you the part number. I'll bet it's interchangeable with your model.
Bill Turpin in WNC mountains
>If the shaft of the switch is threaded and basically 1 3/16 inch in diameter, then any respectable electrical supply (not the borgs)should be able to supply a guard for the switch. Allen-Bradley, Square-D, etc all make them for these standardized industrial switches.
Bill in WNC mountains
Ed
>I thought I was the only one to do that; funny thing it sure takes a long time for it to quit spinning.
Thanks, John.
>Yeak, I look at an exploded view of the lathe and it shows a sheet metal guard. Itme 70 I think it is. I have a fix in the works now to shield that buttom from my arm.
