ADVERTISE HERE - FREE TRIAL
Slight OT - Video Camera
Brodie Brickey
>I'm looking for a video camera to put together some tutorials for some of my project ideas. I was at the AAW Symposium this year and while things were a lot better than previously, there were some video focus problems due to spinning wood and lighting.
So I was wondering what video camera to get. I don't want to spend more than $1000 if at all possible and I'll be hard pressed as it is to justify that to my wife. I also want to be able to provide the best quality image possible.
From what I understand from reading some of the posts, the ability to auto focus on a distance and then turn off auto focus will allow me to show cuts without the blurring issue.
Although I have experience with digital cameras, video is pretty much new to me. What cameras do your turning clubs use?
Any help would be appreciated.
Thanks,
Brodie
Re: Slight OT - Video Camera
>I think manual focus is a must for shooting close ups. The camera quite often won't focus on the correct spot. If you use more lighting it helps but many of them use contrast to focus and when the wood is spinning all the little lines are blured and there isn't any contrast. The ability to turn the focus on and off would be very important to me.
I also prefer the option of manual exposure or at least have a backlight control so that if a window or light is behind you it can be compensated for.
Gary Ratajczak
>I ended up buying a Panasonic PV-GS320. Some of the newer camers shoot direct to hard drive or DVD. DVD is only about 30 min each, and hard drive interpolates video. Mini DV tapes still seem the best option for making demos. My camera is a 3ccd (great clarity and colors), and was a little over $400.00. With the extra money, buy some tripods and sockets from E-Bay, and then outfit them with daylight fluorescent bulbs. They give the best color, and run cool as well.
That should take care of you $1000.
Re: I'm with John on the ........
Jamie Donaldson
>...manual overrides for both focus and exposure. Video cameras have a hard time focusing on a spinning object as you saw at the AAW Symposium, and although the cameras there had manual focus available, some of the operators failed to use it when needed. The DV/MiniDV or HDV format is fairly standard in consumer cameras and offers excellent resolution and other features for less than $1K.
Jeff Rich
>To throw my 2 cents in......
I would go for a 3 Chip or 3 CCD camera for best color and contrast.
Canon, Panasonic, JVC, and Sony have great cameras.
One final word of advice, if you go with MiniDV DO NOT mix brands of cassettes, stick with one brand, the lubricant from different brand can forever clog the head.
Thats why DVD and hard drive recording options are becoming popular.
Peter Hyde
>Stay away from touch screen menus. The genius who thought that up was obviously not aware that most video is shot with the light source behind the operator so the menus are invisible. Add the finger prints and you are really in trouble.
I shot hours of motorcycle hare scrambles and used manual focus all the time. Like you said focus on the distance and the rest is all in focus, no need to adjust anything.
Re: Additional Questions
Brodie Brickey
>Can you edit Mini DV tapes on a computer?
I'd want to be able to transfer it to my hard drive and then cut it down. I'd like to avoid having to go somewhere to edit my tapes down. I had been looking at DVD and Hard Drive cameras only because I wasn't sure if I could edit with Mini DV.
Brodie
Gary Ratajczak
>From the info I found, th video captured onto the direct DVD as well as the hard drive units has a number of interpolated frames. That's done to keep the file size down.
With that said, I did have one of the small cameras that saved direct to memory card. It was a Sanyo. I was able to edit the videos in Photoshop Elements, and they looked pretty good when saved to DVD and played on the TV.
Since I wanted to produce some salable content, I didn't want to take any chances - so I stuck with the Mini DV. There are a number of programs that can be found on the Internet to load the video from the mini DV camera to the PC. In fact, there is software supplied directly with the camera. I use Photoshop Elements, and it will also take control of the camera and transfer your video for you.
I too would like the convenience of the hard drive camcorder, but i didn't want to take the chance. Maybe we can get some input from another user as to their experiences.
Hope the helps.
GR
