Re: You Can Most of the Time
Fog Tanner
>Ken,
If you want to use it as a finish, you need a "finishing resin" or "laminating resin". There are a number of these around, including the Bob Smith brand. I thin the first coat as described, mainly for penetration. I will brush it on with a cheap acid brush, and I usually clean the acid brush (being both a modeler and woodturner). The second and subsequent coats are full strength, which is still thin. For sanding I use 3M Wet or Dry silicon carbide paper, used wet with water. If you put a coat on a day, keeping it leveled as much as possible, there is no need for sanding inbetween. Otherwise, scuff it up with 220 used dry.
Once you have the desired film thickness, add one more. After the last coat sets for a few days, I like to give it at least seven, you can start sanding with 220 wet. You should have done a good job on the lathe with your tools and dry sanding to get it smooth and level. Wet sanding an epoxy finish will only highlight a poor base preperation. After the 220, move on to 320, then 400, 500, 600, 800, and if you are really in the mood, 1200 and then 2000 or 2400. These higher grits are meant for color sanding on automotive paints with the 2000 and higher being used for sanding some clear coats. I also get a lot of my paper from automotive paint supply houses. Especially the 24 and 36 grit Bondo paper I sometimes use.
Wipe clean between coats with a damp Viva paper towel to remove any excess grit. You will be sanding away at least one coat of epoxy, so don't stay in any one place too long as you can get back to bar wood with the 220, a bit harder with 320 and up - but given enough time...
Also keep a fresh supply of paper handy. When it gets dull, change to a new piece, all you are doing with dull paper is rubbing the wood. By the time you get to the higher grits you will have a glass smooth surface which will reflect light. For the ultimate finish you would need to spray on a coat of automotive clear like DelClear or DelGlow and not sand after that. Or you can compund it with one of the 4000 grit compounds, but I don't know that it is worth either the clear coat of compounding. For turned items a good carnuba wax buffed on will work.
