Re: New Shop Heating and Air Conditioning
Steve Russell
>Hello Stuart,
I recently changed out the air/heating in my studio and I looked at lots of equipment, including the self-contained hotel type units, ductless systems, heat pumps, monkey's on treadmills with fans blowing over ice (Hehehehe, just kidding) etc. For years, I operated on window units in the studio and although they worked to a degree, they were never able to keep up with our brutally hot and humid summers... To the degree I would have desired anyway. :-)
I'm lucky in that my A/C bloke is very skilled in his job and I consulted with him quite a bit on what I wanted and what products would meet my needs. One of the problems I always had with the window units was the quick clogging of the filters, not to mention the constant noise. I made up prefilters for the units to help with the dust, but that only worked to a degree. I've stayed in a tons of hotels when I was demonstrating and I'm familiar with the units many of them put in the rooms.
I think these might work, but you still have the noise problem and the filter problem. I opted for a Trane split a/c and heating system, the kind where the compressor is outside and the heater and air handler/ducting is located upstairs. It was expensive but its a dream... :-) It's very quiet and it cools super fast (my studio is 30' x 30'). The heater is sweet and works like a charm as well.
If you go with some type of combined system, it might be a good idea to have an a/c bloke (or yourself if you're handy) build you a prefilter box that will use the newer 5", or 6" thick pleated filters. I use *near* HEPA type filters as my primary filter and the 6" pleated (in-line) filter before the cooling coils. This has worked *really* well for me. My system has been in a year or so and I've changed my prefilters, but the box filter looks fine so far. You can buy these box filters and Home Depot and Lowe's. I looked at my coils and they look new, without any visible dust on the fins.
If you can build one of these prefilters, your life will be much easier and simpler and you will not have to clean your a/c internals nearly as often. I really liked the look of the Mitsubishi ductless systems... Take a look at these. They use a 3" hole through the wall and mount on the wall, not in the window. The noisy parts (compressor and it's fan) are located outside, so they run quieter.
I should mention that I also use "point of service" dust collection through a 6" hose when sanding and also a secondary large air filter collection unit as well. Very little dust escapes these two units, so my a/c filters are not overworked. Whatever you decide, get ample cooling capacity... IIRC, you're in Texas, or as we like to say HOTexas down Houston way, so you need lots of cooling capacity when the temps hit 100 degrees plus, with 99% humidity. :-o Good luck to you and best wishes in all of your woodturning endeavors!
Steve Russell
EWW, WVP
The Hot, Wet and Humid Woodlands, Texas :o
