roughing Red oak
roughing Red oak
roughing Red oak
Mike Nelson
>Just cut down a large Red oak and had to cut out the stump, just shoot me next time! The wood is beautiful, burl and spalting. I roughed to 3/4" on a few bowls 8" or so, then sealed with CA glue all over and inside the rims. I know oak cracks bad, anybody tried this or have other hints?
Re: roughing Red oak
Mike Nelson
"CA glue all over"? As a sealer?
adrien
Bob Moffett
Bob Moffett
>I have had good luck with Red Oak by roughing it out to about 10% thickness and then putting it in a paper grocery bag full of shaving and leaving in the basement for 6 months or so.
ryker acuna
>Just finished two red oak hollow forms from a tree cut down a month and a half ago. Alcohol soaking. Got the information from someone on this site. Maybe they will chime in with website info. Best process I have ever used. Very marginal warping. Check it out.
C.W.Stivison
>I was turning a small crab apple bowl that kept wanting to check and I used CA to seal the entire bowl. The checking stopped and it finished nicely. I don't know about sealing it before it checks. Let us know.
CW
CA glue all over
Mike Nelson
>Adrien, CA is a great sealer and an even better finish! Unless you order 16oz bottles and get the big bucks for your pieces, it is way to expensive for large projects. On big bowls I use Elmers white glue, I place them upside down on a small log with lots of shavings on the floor to catch the overflow and pour it straight out of the gallon jug. This leaves a thick clear seal and the bowl or whatever dries from the inside out. I hope the CA works on this oak, if not my wife has a little grinder that turns coffee grounds into bark inclusions!
