vacuum gauge
vacuum gauge
vacuum gauge
Dave Winters
>My vac gauge is a liquid filled deal, and it's got an air bubble in it. And, it reads like 4 inches even when the pump is off. There are two screws in the back and some kind of rubber cap on top.
Is this thing FUBAR or can I somehow add liquid and adjust the needle?
Thanks..
Re: vacuum gauge
Re: vacuum gauge
Roger Smith
>Dave, most liquid filled gauges will have an air bubble. This should be OK. Yhe oil acts as a damper. I would test it against another gauge and compare the reading at a couple of different pressures.
Re: vacuum gauge
Probably okay
Guy in Cuba
>Vacuum and pressure gauges filled with oil almost always have a gas bubble to allow for expansion and contraction of the oil due to temperature changes.
The rubber plug covers the diaphram that allow the gauge to use that outside pressure as a reference. One of the screws is probably an adjustment screw. Depending on the range of your gauge, 4 inches of pressure may be easily adjusted, or not.
Good luck,
Guy
Re: vacuum gauge
Re: vacuum gauge
Dennis Daudelin
>Hmm, 4 inches...
Most vacuum gauges show 30 inches on them. But in real life we can only pull down 26 inches. So, I wonder if the previous owner(?) adjusted the gauge to read 4 inches on purpose?
It's just too much of a coordinated instance...
Dennis
Re: vacuum gauge
Re: vacuum gauge
Mike Nelson
>Dennis, I'll take your word for it but it seems to me if you had a heavy hydrolic type cylinder, one could implode the valve and cylinder pulling a vacuum. Why only 26?
Re: vacuum gauge
Re: vacuum gauge
Bill Howatt
>Not clear on the cylinder issue you mention but I think Dennis is referring to the typical best reading you get with a pump and blank mounted on the lathe. There are enough tiny leaks in the system along with the ability of the pump to make around 26" a typical maximum vacuum.
Bill
Re: vacuum gauge
Re: vacuum gauge
Dave Winters
>I tried the two screws in back of the gauge, and oil drips out of them, but I don't see any adjustment...
Re: vacuum gauge
Re: vacuum gauge
Pete in Holland
>Seems the gauge has been spiked at one time, making it read 4" off.
On the flip side, us turners normally don't need to know exactly what vacuum we are using, only that we have enough. If your gauge still functions, but is a few points off, is it really a problem? Turners rarely need to know the exact amount of vacuum we are drawing, only that we have enough. If at "x" inches of vacuum on the gauge, the bowl stays on, don't go below that point.
Liquid filled gauges, unless they are pretty expensive and can be recalibrated from the outside, are throw-away items.
Use it as it is for reference to a vacuum pressure, or buy a new one if you need to know the exact pressure you are working with.
My 2 cents.
