The lathe cleaned up nicely!
Eddie Pacheco, San Jose, Ca.
>Well, after some major grunting my buddy and I got the lathe bed off the trailer and back upright. While it was on end I drilled out and retapped the threaded holes on the bottom of the legs for 1/2-13 UNC thread to fit some casters I had stashed away. The casters are just temporary so that I can move it around until I reassemble and get rid of the PM90 lathe. I used my automotive floor jack to raise and lower the lathe at each end to remove/replace the casters and this scheme works fine.
The s/n is 9852138 so I guess it's a '98 model that was made in McMinnville, TN. The headstock and tailstock line right up!
Have a nice weekend!
Re: The lathe cleaned up nicely!
Jennifer@Indy.USA
>Nice snag Eddie. Lucky Dawg!
Brent at Robust
>Great Buy, Eddie. One thing to watch out for is this looks like the narrow base model, and you'll need to be careful if you do anything large and out of round. A friend of mine who is a professional turner of large pieces has the same model, and he bolted angle irons, about 30" long, across the base to reduce the risk of tipping when he does big pieces. If you look at the newer models, you'll see that the base has been widened.
Good luck with it, it looks like it's in real nice shape and will give you may pleasurable years of work.
Allen Neighbors
>Good show, Eddie! Perfect lineup. Nice buy, and you'll get a lot of years out of it!
C.W.Stivison
>The only thing that could make any better would be to have shavings all around.
CW
Barb Siddiqui
Congratulations, Eddie
Barb Siddiqui
>Boy, are you ever addicted!
Hi to Nancy....BarbS
Thnx, Brent. Yes, they are 18" wide at base.
