Re: Drill Chuck for my Lathe
Bill Howatt
>Get a regular Jacobs chuck that will open to hold a 5/8" dia drill bit. That should cover most any drill sizes you would use. You don't have to get a real expensive one, I'm going to say in the $25 range. If it comes with a mandrel be sure it is a MT2 like your lathe. You may have to buy it separately. If you do, make sure the taper on the other end fits the taper specified for the chuck. They are often numbers like JT6.
One other thing that will make the chuck a bit more useful is to make sure the MT2 end has a threaded hole in it. Often, the threaded size is 1/4-20 or a bit larger. This allows you to insert a threaded rod through the headstock and into chuck's mandrel. You then put a washer and nut/knob on the end sticking out the back of the lathe and tighten it. This way you can use the chuck to hold items without having the chuck come loose in the headstock. When the chuck is being used in the tailstock, the pressure exerted by drilling is enough to keep it forced into the tailstock.
Bill
