Mark Kauder, Phenix City, AL
>Quite a few years ago, I wrote a posting about how I changed my Jet Mini lathe to a variable speed lathe. And in conjunction with that thread, there were some postings about how to make this arrangement so that the motor is reversable.
I have the basic document, but no documentation on the reversing part. I am out in Arizona, and meeting with Carol "The Router Lady" Reed. She is trying to set her lathe up with one of these motors.
I know one of you out there must have better records than I do. You must have a copy somewhere on how to reverse this motor.
Help!!
If not, when I get back, I can probably take the lathe housing apart and figure it out.
Thanks, Gang
Mark
Re: Help on Variable Speed Lathe Article I Wrote
Re: Help on Variable Speed Lathe Article I Wrote *LINK*
wilbur
>Google is your friend!
Try this web page. You're credited on it. The diagram for the wiring for the reversing switch is linked about 2/3 of the way down.
I am assuming that the Vega control board in this web page is similar to what you used in your original post.
Variable speed and reverse upgrade
>FANTASTIC !!
DUH, You got me on that one. I searched all of Woodcentral/Badger Pond, and my own files, but forgot Google.
Thanks
Mark
Couldn't get the link to work, and...
Clem Wixted, Jonesboro, AR
>... went to the club site and the internal link didn't work either :-(
eaglesc
>If the motor is D.C. can't you just reverse the polarity?
