REAL MILK PAINT
How thick for a large bowl
Steve Kubien
Steve Kubien
>I've roughed a green, maple 16" x 5" deep bowl to 1.25" thick. If I want to finish turn it now and let it distort, how thick can I leave it with minimal chance of it cracking? I'd like to leave it 3/4" for looks. Is that too thick? The blank is from the middle of a straight trunk and the tree was downed last week. I'll try to post a pic later tonight (probably add it to Barbara's 'just a bowl' thread).
Thanks
Steve Kubien
Re: How thick for a large bowl
Jorge Castaneda
>Steve,
A consideration is that such a large bowl finished to 3/4"will be a very heavy dude. I Leave the 14" bowls that I make at 3/8" and the rim area at 1/2". Maybe 1/2" for a 16" will be just right.
The ladieas like them light.
Jorge
Mac
>Steve, If you leave it 3/4" thick,it is most likely to split.As Jorge says,3/8 or even less will lessen the chance of it splitting.Try to leave a bit more in the bottom so that you can sand it flat after it twists.Making the bottom concave will help some. If you lose it,its a lesson learned.
Richard Allen
Richard Allen
>I currently have a 16 1/2" x 17" oval, 4" deep 1 1/2" thick maple bowl that is now dry and without any cracks. Someday I will turn it round and finish it. The bowl will likely end up with a 3/4" rim and 1/4" sides. Looking at the bowl you will see a thick bowl but the weight will be of a 1/4" to 3/8" bowl.
The point is that you can finish turn the maple bowl to an even wall thickness. Slow down the transfer of moisture, perhaps by putting a finish on the bowl or keeping the bowl in a humid environment (paper bag perhaps). Keep an even wall thickness.
robo hippy
>All of my bowls are green turned to final thickness and allowed to warp before sanding and finishing. Max thickness would be 1/2 inch, but most of the time, I am around 3/8 to 5/16 thick. Slow dry it, even paper bag it depending on local humidity and temperature. I use the LDD (liquid dishwashing detergent) soak which doesn't aid drying or stability, but makes a big difference in how it sands out.
robo hippy
Steve Kubien
Thanks for the help
Steve Kubien
>I got it down to 3/8" last night. I would've tried going a little thinner but I got a nasty catch and decided to quit before I was forced to. I need to make a large dougnut chuck to hold it so I can finish the bottom. I really made a mess of it (the bottom) and hope I can save it. I didn't plan the holding methods well at all on this one. If not, well, I suppose I could urethane the heck out of it and call it a planter!
I promise pictures when it is presentable.
Steve Kubien
Ajax, Ont
