Do you guys and gals have any trouble turning walnut? For some reason I seem to get these hair line checks after I have almost completed the bowl for HF. They always seem to appear. Most of the wood has been cut for a while but it still has some mositure.
The thickness of the piece is in the 1/4"-3/8" range
>I haven't had any trouble turning walnut. You can easily get surface cracks if the wood is partially dry, or heat checks from excessive sanding. If you take a really long time to turn a piece you can get checks. I will periodically spray a piece with water if I'm going to be very long. If I leave it for any reason I cover it with plastic bags. Some others may have encountered other reasons for surface checks.
>I do the same as John. If I'm going to have to leave a bowl on the lathe(or any other form) and be out of the shop, I give it a quick spray with (soapy) water and wrap it in plastic.
If you'll slow down the sanding speed, or wet sand, you may find you'll have fewer checks. But that all depends on a lot of variables...
I've got quite a bit of (English?) Walnut that was dead for a year or two before it was cut down, and there are quite a few checks that have appeared in it as I've turned it, in spite of being careful. And in the past, I've had Black Walnut that I cured for several years in log form, that seldom had a check. So I guess it all depends on the wood, the environment, etc.
Thanks for the info. I have not left a piece on the lathe so I guess it is my sanding and tool work. I noticed when turning the inside the dust can get rather warm and I do push a bit when sanding the outside so the sanding medium does get hot.
I thank you again for helping me solve my problem.
I guess a little bit of everything, try sharp tools and small bite and slow movements (but not too slow, that would make heat too) and take it from there.
