Coin inlay tips?
Coin inlay tips?
Coin inlay tips?
tm
>I got "volunteered" to turn an 8 inch platter for a silent auction fundraiser at the aquarium where I work.
Its not exactly the kind of piece I really like to do but I dont have much experience with inlaying. I was given a comemorative medallion that I thought might inlay.
I'm guessing I need to turn a tight rebate and plant the slug with CA
glue. Any pointers?
Thanks,
tm
Re: Coin inlay tips?
Barbara Gill, Remlik VA
>I would use either the flexible CA or some other type of flexible adhesive.
>I use a product called Elmers f26 for gluing metal to wood when it doesn't show. It's an ugly tan color but it stays flexible. Since the coins will be in a rebate I think just about any glue would work.
Mike Stafford
Mike Stafford
>There have been several discussions about what adhesive to use for inlays of wood, metal and other materials such as stone cabachons. It seems the consensus is that you should use a flexible adhesive as Barbara and John have suggested. I recommend the lightest dab of silicone. Remember, a little dab will do ya'.
Boy that's an old commercial. :)
>Did anybody actually use Brill Cream or whatever it was?
RP
>I put quarters in all of my bowls with the date up so people will know the year I gave it to them. I use a forstner bit. I used to turn the rebate, but the forstner bit works quicker and using a chuck in my tail stock, it is very consistant.
The bit I use is a tad bit larger than the quarter. This allows for expansion and contraction of the wood. I use 5 minute epoxy. I put a dab of both right in the rebate and mix it in the rebate with a popcicle stick.
The only problem I've ever encountered is in green wood. I've had bowls curl up so badly it pops the coin out or leave an edge sticking out a little. But that was when I was turning the rebate. Now that I've been using the forstner bit, the bowls can do all they want,and the coin stays put.
Don't know if this helps, but it is what I do.
RP
Re: Yep.
Allen Neighbors
Re: Boy that's an old commercial. :)
Tony Reynolds somewhere near Newark, Ohio
>Man, now I feel old! IIRC that was Dip-a-di-DOO (sp) A little dab will do you.
Tony
tm
>Thanks everybody,
John
Re: Nope, it was...
Allen Neighbors
>"Brill Creme... a little dab'll dooya!" Hair grease in a tube!! Yuk!
Re: I did and look at me now!!!!!!!
Curt Stivison
Nah, I used Butch Wax
tek-Brunswick, Ohio
>I used Butch Wax until I was in the 7th grade. Then came the surfer look. Then the hippie look and now the high forehead look.
Re: Nah, I used Butch Wax
>I was afraid I got the high forehead look because I didn't use Butch Wax.
