question qabout oil-hardened steel
eliot d
>Is oil hardened drill rod already hardened? ( I would think so.) But a guy I know thinks it's TO BE oil hardened; i.e. it's not hardened yet but is of a composition so that it can oil hardened.
eliot d
Re: "guy I know" is right. It's dead soft.
Al Crandall (N.E. of Indy)
Re: It is not pre-hardened,...
Allen Neighbors
>but it is harder than a Oneway Toolrest (I don't know what sort of steel it's made of). I used O-1 1/4" rod to edge my toolrests, and it doesn't nick as bad as the toolrest did.
If you want it hardened, you need to order it that way. If you try to harden it, it will warp out of shape.
Re: question qabout oil-hardened steel
Richard Allen
>O-1 steel is High Carbon Steel which can be hardened with a MAP gas torch. Heat to red hot and use oil to quench the steel. Once cool you need to temper the steel (soften it a little) buy heating the steel. Watch for a "straw" color as you heat the hardened steel. You can also send the steel out to a service for hardening and tempering. You should do any and all machining on the soft steel first. You will have to work hard to shape the hardened steel. You can also remove the temper from HCS if you try to shape the hardened steel.
HCS tools are often heat treated only at the cutting edge. When you grind past the hardening you shape and then re-harden the the new cutting edge.
To test if steel is hardened run a file over it. If the file "bites" it is annealed (soft). If the file skips across the steel it is hardened.
Hey! I'm that guy.
Bob Stroman
