want to save this pen
arw01
the bottom barrel blew out. The top is solid. Wondering what wood would compliment the top the best for the shaft of the pen?
European style pen, BTW.
Alan
Re: want to save this pen
Cyril Griesbach
>Alan, I think I'd go with something darker than the top. Perhaps Cherry or Mohogany but not as dark or open grained as Walnut. That way it would better show off the spalting of the top.
Cyril
Bob Way, Canton, MI
>I'd go darker as well. My first thought was ebony or african blackwood. One of the redder woods might work too. Something without a lot of grain or pattern so as not to detract from the spalting. I haven't done anything with dyes, but there may be some options there to accent as well.
Bob Way
Canton, MI.
eaglesc
>I would attempt a repair a different way.
I would flip the blown out section ene for end.
That would put the damaged section where the CB is going to be.
I would then part of the remaining damaged section and make an "oops" band out of a "matching" light coloered wood such as aspen.
I then would turn close to finished dimension leaving the blank a little proud.
I would use a dremel tool and an engraving or dentist dit to make a random swirl around the blank and fill in with ebony dust and CA.
Let it harden overnight.
Finish turning the pen and finish.
Procede to part off for the tenon for the CB.
I don't think such a repair would be that noticeable.
Consider it a "design" opportunity.
An "oops" band would stick out like a sore thumb unless you did the same thing to all ends.
If my suggestion fails you can always take the easy way out.
