Veritas - Innovation in Tools
Shop Shelving
Shop Shelving
Shop Shelving
Sean Troy
>I,m starting construction on a new shop next week and was thinking ahead to shelving for storing rough turned items. I need some recomendations as I have always just placed them on the garage floor. Thanks in advance. Sean
Re: Shop Shelving
Dick Hines
Re: Shop Shelving
Dick Hines
>The floor may be the best place to put wet roughed out bowls. It is cooler no the floor and may be less sun light.
Re: Shop Shelving
Re: Shop Shelving
Ray Thompson - Middletown,IN
>I would use the open wire stuff, should be great for air flow. Uprights bolt to the wall with adjustable brackets. It comes in different widths and the shelves can be adjusted easily depending on your mix of blank sizes at any given time.
Ray
Re: Shop Shelving
Re: Shop Shelving *LINK*
Bill McWhirter
>Sam's, Home Depot, and Lowe's all carry moderately heavy duty wire shelving units. They will hold most anything you want to put on them, are not difficult to assemble, allow good air circulation, don't collect much dust, are adjustable, and come with casters. Considering the cost of lumber, the price is not terrible.
http://www.samsclub.com/shopping/navigate.do?dest=5&item=168602
Re: Shop Shelving
Re: Shop Shelving
>Sean I have so much junk and wood that I don't have any choice. I can't possibly put everything on the floor. I have some shelves that were there when I bought the place and I've added some wire shelving. I think I like the wire better but I'm not really sure. It doesn't collect dust on the shelf itself but you also can put very small items on the shelf. They also come in just one or two depths so if you want custom sized shelves you still end up going with plywood.
I prefer cabinets and drawers and will eventually go there but of course that's even more money and the time to build them. What I've decided to do this time around is build the cabinets but make them in sections and mobile. I don't plan to stay in this house more than 5 to 7 years so Iwant to be able to take all the shop cabinets with me.
Re: Shop Shelving
Re: Shop Shelving
Sean Troy
>I like the idea of those racks. I suppose I could run longer sections of the wire racks like they have at the big box stores.
Re: Shop Shelving
Re: Shop Shelving
>Yea but then you'll have to change the inventory around weekly so no one can find anything. :)
Re: Shop Shelving
Re: Shop Shelving .... wow, John
Ruth Niles
>You are so organized, you know what you want for the future and how long you plan on staying in your "new"er home. I have a hard time planning 3 days in advance!
Having just built my new shop (which I dearly LOVE), I have plywood shelves (cheap and custom sized from 4" to 14" deep), one metal shelf like the Home Depot link posted above (good, movable (ha, not with all the junk on it!) and solid, not my style), 2 wire home closet style (great to keep clean of chips, great for wood, great for cans of finish, lousy for tools).
Re: Shop Shelving
>Ruth That's not really planning, it's dreaming. My son will be out of college in 5 years. I'll have 25 years at Tech at that time. I will look at retiring. In reality I'll probably have to stay till 30 and may get to retire but will still have to work somewhere just not here. I would like to move closer to my parents, North Caroline, North Ga, or Chattanooga area but who knows what will happen in 5 years.
Re: Shop Shelving
5 years isn't as long as
Stuart Johnson
>it used to be.
As the saying goes "Life is like a roll of toilet paper. The closer to the end the faster it goes"
Re: Shop Shelving
Re: Just a thought - adjustable shelving??
>How about the Rubbermaid or Closetmaid adjustable shelving? I've used them or Elfa in most of the closets in the last two houses. They do make sturdier verisions for the "garage" (shop). I even put them up in the parish hall closets at our old church (where they still hold plates, glasses, etc.).
Re: Shop Shelving
Re: Shop Shelving
>Sean I had to photograph custom shelving for a company that makes them a few weeks ago. They make fairly high end walk in closets and have decided to get into the garage and workshop cabinetry business. It's pretty nice and great to look at but I don't think it's rugged enough for my use. The workbench was the biggest joke. I can't imagine trying to dissassemble a Harley motor on it, or even trying to plane wood. You might be able to rebuild your weed eater on it.
Re: Shop Shelving
Re: Shop Shelving
Sean Troy
>Workbenches, thats another thing I've been trying to work out. Monday is groundbreaking so I better get on the ball.
Re: Shop Shelving
Re: Shop Shelving
Allen Neighbors
>Sean, I built my own workbench... sort of along the lines of the "Lervad" style, only instead of maple, I used Pine wall studs.
On edge, 15 2x4s plus 2 3/4" boards for bench dog spacers will make a bench 24" wide. And you could rebuild a train engine on it!
Re: Shop Shelving
Barry Turner
>Just because you have a plan.......doesn't mean it will come together. Joyce and I only "planned" to be in our current house five (5) years max. We've been here 36 years. Maybe if I didn't spend so much money on woodturning it would be different?
Re: Shop Shelving
Re: Shop Shelving
>Sean The June Popular Woodworking issue #162 has an excellent article on workbenches and things you might want to add to your workbench.
Re: Shop Shelving
Plans don't always work
>Barry I was planning to stay on this job 3 maybe 5 years and then move on. I've been here 20. Man does time move fast.
Re: Shop Shelving
Re: Shop Shelving
Jerry Hall
>Sean, I have used an old idea from Fine Woodworking's Small Shops book. Post's lag screwed (3/8") to studs top and bottom, resting on the floor againsT a wall. They are pre-drilled with 3/4" holes every 6" to receive 1/2" black pipe shelf supports. Mine are 4x4's. I use odd lengths of pipe for wide or narrow shelves. It is a sturdy and very flexible system. I put the holes in at a small angle, 5 deg, so that work or lumber would not slide forward. I got a lot of unthreaded pipe cutoffs for free from local hardware store. I used the plastic thread protector caps to make the sharp pipe ends bump proof. It is cheap, fast to install, and holds heavy loads with ease. When I run out of shelf space I plan to put some holes and supports in my garage door header as well to store rough turnings waiting to dry. Jerry
Re: Shop Shelving
Adjust-A-Bench *LINK*
Bob Stroman
>This is a great solution if you use for different things and want height adjustability. It's very sturdy.
http://www.adjustabench.com/
