mounting heavy blanks
Steve Kubien
Steve Kubien
>Hi everybody,
I've just scored some nice, large, green maple logs and want to mount them on my Nova 1624. I only have the 3" faceplate which came with the lathe and I want to rough turn these before I get another faceplate. Do you think it would be safe to bolt the 3" faceplate to some heavy plywood (thinking 2 x 3/4" thick) and then use (a bunch of)lags to attach this new 'faceplate' to the blanks? The blanks are 18" across and 8-9" thick, freshly felled today so they are very wet.
Thanks for your help,
Steve Kubien
P.S. I've got 9 of these suckers to get through. I love tree services!
Re: mounting heavy blanks
Bruce Forrest
>I would never use plywood. It will delaminate. Disaster will follow.
Richard Allen
Richard Allen
>Use your tailstock and the 3" faceplate should be fine. Oops I see that you will be turning outboard. Get a good solid 6" faceplate.
If you absolutely have to use the 3" faceplate without a tailstock then use a solid wood board between to make a "larger" faceplate. It would be best to bolt the solid wood board rather than just screw it to the 3" faceplate.
Allen Neighbors
>I use a 4" faceplate for green blanks up to 24" dia. I use the tailstock for extra strength until balanced. If I couldn't use a tailstock, I'd try to balance the blank before putting it on the lathe, and I'd use longer screws. I'd give it a try, anyway. I don't understand how wood between the faceplate and the blank (which is also wood) is going to change anything. If I had to use something between the faceplate and the blank, I'd try to find some 1/4-1/2" steel plate and bolt it to the faceplate, and then screw through that.
Just my opinion.
Steve Kubien
Thanks everyone
Steve Kubien
>I should have mentioned that my intention was to bolt everything. No woodscrews for this operation! Allen, I like you idea of using some 1/4-1/2" steel plate. I may even have enough to make a 6" plate. I'll mull this one over a bit before getting hurt.
Cheers,
Steve Kubien
Brian Hahn in SW Wisconsin
>My rule of thumb: When in doubt, use a larger face plate.
I would use a 6" face plate.
Philip Duffy
>Steve, Last week I had an 18in diameter cherry platter blank fly apart at a bark inclusion and strike me in the upper left arm. The result; 2 weeks of pain and a shattered dream. No broken bones but the impact has disabled me for a long time in recovery. I would examine your blank carefully and use the biggest and strongest mounting you can find. Good luck. Phil
Check out JET faceplates at Cutting Edge *LINK*
Craig Daymon
>Steve,
I recently ordered a JET 8" faceplate from Cutting Edge Tools. It's a copy of the Oneway, but is only $65.99. The 6", which probably would have been enough for me, is $52.99. I can't say for sure yet, but these should be solid, reliable faceplates. They have lots of holes for screws, just like the Oneways.
I picked up some large aluminum faceplates that were on sale at Woodcraft a while back (I think they were Nova faceplates), but they seem to flex under load so I wanted something more solid.
As a side note, Cutting Edge has the Norton SG grinding wheels for almost half what others are selling them for.
-Craig
Cutting Edge Tools - Faceplat page
Steve Kubien
Got an 8"
Steve Kubien
>I went with the advice from here and the warnings about safety and picked up an 8" faceplate at Busy Bee today. Probably won't turn this sucker until next week because we're out of town for the weekend.
Thanks again,
Steve Kubien
