Resin Stabilizing
Resin Stabilizing
Resin Stabilizing
Ken Oakley-Sunny St. Cloud, Fla.
>In my most recent Rockler catalog they have wood burl pen blanks they claim are stabilized with resin. Must be something great because most types are $6.99 per blank that are 3/4" sq. and at least 5 1/4" long.
I sell blanks, mostly citrus woods, and feel lucky if I can get $1.00 ea. And mine are 13/16" sq by 6" long. Can somone explain the process of resin stabilization so I can charge more for my blanks?
Re: Resin Stabilizing
I believe it is just ....
Bert
>a big pressure cooker type set up. They put the blanks in a bot of resin, close it up and pump in pressure to force the resin into the wood.
They do make some nice pens.
Where can I buy some of your citrus blanks?
Re: I believe it is just ....
>I normally sell on Ebay, but email me and we can talk-- Also thank you for your reply
Gary Evans Tallassee, TN
>Hi Ken,
Actually, from what I know about it, the process is done under vaccum. You evacuate the space where the blank/blanks are and then introduce the resin as the blanks are returned to atmospheric pressure. I haven't done this myself, so don't hold me to this.
I've been wanting to try this with shellac as the resin. As thin as it is, I'd be interested in seeing how far you could force it into the wood.
Gary
Gary
>Sounds like it is a little beyond the scope of things I can do with the equipment I have. I have worked with vacuum chambers in the past when making RTV molds to eliminate air bubbles in the rubber when casting the mold. But I don't have a vacuum pump and don't want to build another chamber at this stage in my life. I'll just stick with what I can get from Mother Nature.
dwr
>Ken,
It's a combination of vacuum to remove the air/moisture in the wood and pressure to force the stabilization material into the wood and heat to cure the stabilization material.
There are a number of home brewed stabilization processes, with mixed success, but none that produce the same results you get from the retail versions.
