>I just purchased a Delta 46-715 lathe. This is my first lathe so bear with me while I describe my problems. I am just through the assembly stage, and on the headstock I am supposed to remove the round disk that is used for bowl turning. The instructions state to insert the bar into the shaft and turn the wrench counterclockwise. Unfortunately, this nut will not budge. I called Delta and they recommended installing a 2x4 with screws into the bowlturning device, and use a pipe wrench to remove the nut. Still no go.
I assume the "device" you are mentioning is what the rest of us call a Face Plate. I am not familiar with the lathe you mentioned, but there should be others chime in here. Be sure that you are trying to screw off the face plate in the correct direction.
>Scott I had one many many years ago so I don't remember the details. You are trying to remove the faceplate. It should unscrew counter clockwise or as you stand at the front of the lathe pull the top towards you. I don't remember how the spindle locked on that lathe but you will have to lock the spindle to keep it from turning while you unscrew the faceplate. The spindle will either lock by pushing a button or you will have wrenches to hold the spindle to keep it from turning.
>I looked and there is definitely not a set screw holding the collar. Just to make sure that I am not a complete idiot, you insert the bar to hold the rod and you use your other hand to push the wrench down towards the ground, which would be counterclockwise. Is this correct? How tight should the faceplate be installed, under normal conditions?
>Scott, there is a hole in the spindle (the thing the faceplate screws onto). Put the knockout bar in the hole and let it jam against the lathe bed to hold the spindle in place while you unscrew the faceplate. As JL said, check first to be sure there is not a set screw holding the faceplate to the spindle. You might have to give the wrench a sharp tap to get the faceplate loose. If you can't get it off, just post a message for Ruth Niles...she's an expert at removing stuck faceplates! LOL
>Under normal circumstances, the faceplate should be installed just finger-tight, that is, screwed on snug without benefit of any wrenches. Sometimes, it will get tighter as you turn, especially if you are roughing a large bowl blank. Some recommend using a plastic or thin cardboard washer between the shoulder of the faceplate and the spindle to keep it from sticking.
Maybe you could just print a picture of Ruth's BENT wrench to the lathe so it could get the idea.
On a more serious note, search the forum for the stuck faceplate, and you will find a fairly recent thread where all manner of valid cures were proposed.
>Scott, when you have the spindle locked you need to give the wrench a sharp rap or two with a heavy mallet.This might require a third hand from someone...been there, done that.
>Scott, just thought I would mention that. Depending on what spindle lock mechanism your lathe has, if the faceplate is really on tight and you try to remove it using the spindle lock instead of the knockout bar, you may break the pin on the spindle lock. Again, just ask Ruth! LOL
>Scott, I had that lathe. With the faceplate to your right, you should find the index pin/lock pin on the lower part of the opposite side. Pull it out, twist slightly, and let it back in. Done correctly it should lock the spindle. At this point a wrench (I think one was provided) should be able to loosen the faceplate. A tap with a hammer should do it. If not, try a long pipe over the wrench handle for additional leverage.
I'm assuming this is a new lathe. If not, are you possibly dealing with rust in the joint? If so you might need to apply a solvent like Liquid Wrench to release the bonding.
>First, like Carole said, do NOT use the index pin. I have a General, very sturdy hunk of iron, the index pin snapped when I used the pipe wrench (the wrench bent, too). If there is no set screw holding it in place, try every one's suggestions, which is what I did; just do it all. What worked for me was putting a 27" long piece of pipe on the handle of the pipe wrench, used a clamp to lock the spindle from turning (don't know how to do that on your lathe, the General has a locking button), then I rapped the end of the pipe with a small sledge hammer. What I really did to get it off was heat the spindle and face plate but DO NOT do that either.
>ice the spindle to make it shrink. You can heat the faceplate (to make it expand) with a hair dryer but do not overheat as that will melt the seals in your bearings. Try the ice for about 15 minutes before applying the heat. Immediately after heating, with a wrench of some sort on the faceplate, give a quick rap to the wrench handle. If it is a new lathe I would not do anything that would void the warranty; instead I would take it back to where I bought it and let it be their problem.
>I would have taken it back right after there tech support suggested using a 2x4.That kind of advice gets me thinking real hard as to what kind of company I am dealing with.I don't know anything about this lathe,price ot otherwise,but I just got the Nova 1624 about a mo. ago and it took me about an hr to have it up an running.I did a lot of research before getting it an the three lathes lowest on the list for quality were sears, HF and delta.Sorry,but maybe this was one of the reasons why.Good luck.
>These are all great sugestions but if it is new and you bought is close to where you live I wouild make the vendor fix it. If you screw it up it is yours.
