Dust Collector/composting question?
>Dave Winter's post about a fire in his Dust Collector (Glad you are OK, Dave)prompted me to ask:
Has anyone had their DC bag start to compost or go into a heat? I doubt that dry sawdust would do it, but wet stuff might. A lathe can produce a lot of wet shavings.
Re: Dust Collector/composting question?
Ken Grunke from SW WI
>I think the chance of straight wood shavings heating up are slim, but adding green vegetative matter and animal poop would help.
Russ Fairfield
>The odds of that happening are the same as the odds that the entire system will explode from the static electricity that builds up on plastic duct or flexible hose.
Mark Kauder, Phenix City, AL
>Yeah, I used to be into gardening and composting. For good (hot) compost, you need stuff with Nitrogen and Carbon (and moisture). Wood dust is high Carbon and mostly dry. Fresh cut green grass is high in Nitrogen and wet. For a good compost - you need a good balance. Grass will compost in a matter of days in your mower bag, but will smell bad, maybe even get slimy and moldy. When a compost is moving slowly, you add nitrogen, getting too hot (and usually sulfur smelly), you add carbon.
Dry Wood dust in your DC - forget about it. Wet chips from a turning, with volume, maybe - but will not get very hot w/o the higher nitrogen. You will not get the mass needed for it to get anywhere near hot enough to catch fire.
Mark
