>Does anyone know the eqivalent grit sizes of the DMT diamond hones. All they say is course fine and extra fine. I want to know how they relate to my old EZE-lap. I found a chart somewhere that said that the EZE-laps were approx. 180 grit for course, 270 grit for medium, 600 grit for fine and 1200 grit for super fine. I doesn't really matter of course I'm just curious.
>I bought the individual diamond honing plates from HF and the backing separated after a few uses with oil as the lubricant. Maybe water would have been better?
>Having a Senior Moment here. I bought some diamond hones at WoodCraft, the red green and blue set John is talking about by DMT or who ever. I got the small ones about an inch by two and a half to try them out. I went back and sort of casually asked "Do these things wear out?". The Clerk and the owner agreed that they do and that you should not lubricated them with oil(?) because it floats the diamonds off. Now I am not sure what he said. I will have to ask again.
>I bought the DMT set at the local knife shop. I've purchased the EZE-lap from lots of different places like Highland Hardware, Craft Supplies and Woodcraft.
I've been wanting to try the DMT set to see if there are any differences from the EZE-LAP. The EZE's do wear out although they last a long time. They just don't cut as quickly as when they are new. I lubricate them by licking them. No seriously I usually just lick my thumb and then run that over the hone. One of these days I'll start using water. Since I usually only use one hone to clean up an edge it's just faster to do it the redneck way.
I haven't tried any of the diamond hones with the holes in them. Maybe next time.
>Barry, The ones I bought from HF were the 2" X 6" ones with holes and backed by red, yellow and blue plastic plates. I used oil as a lubricant while honing. The plastic plates separated from the perforated steel plates that carry the diamond grit.
I have a set of the foldable ones from Woodcraft that I have been using dry for a few months and they seem to be holding up fine.
>I've been trying to find a good diamond hone for my spiraling system. I am not happy with the EZ Laps as they wear out way too fast. I am now trying one of the DMT Diafold and a Grizzly unit with the holes in the system that allow the metal to scrape into (theory the store clerk had) and so far they seem to be doing better but are still new enough that I need more time to determine if they are going to last longer then the EZ Lap. Below is the color code chart for DMT. Grizzly unit can be found at: http://www.grizzly.com/products/h7610 (can't put but one link up!)
>The above in Sevierville, TN is a very good place to purchase diamond hones and othe sharpening stones. They have an excellent selections. Prices are competitive, too.
