How do I sand my legs?
Joe in a Cleveland suburb
>Hello.
So I have these four legs turned and they are all pretty similar. I've been trying to sand them smooth but I'm having a hard time. I've never had a hard time sanding so this seems odd. Must be something very simple I am doing wrong. I have very little experience sanding round things on the lathe. In fact I prefer using scrapers and planes on flat stuff! Can I say flat stuff over here? Didn't break a rule did I? :)
I am using quality paper and going through the grits. I keep getting scratches though. It's as if I can't get rid of sctratches from the 100 grit paper. What's the trick? I'm doing this on the lathe. Should it be spinning fast or slow? Pretty soon I'm gonna end up with tooth picks.
Suggestions?
Thanks
Joe
You can see the legs here if interested
Re: How do I sand my legs?
>Sand with the grain wherever possible. I sand with one grit. Then I use the same grit and just touch is lightly as it spins. Then I stop the lathe and sand with the grain any place that I can. Then I do the same process with each grit.
Re: Very carefully... it hurts! :)
Allen Neighbors
Bob Way, Canton, MI
>I use a process similar to John's, now. Only thing I'll add, though, is when I first started out I was a bit heavy handed, meaning I would press the paper too hard against surface. The granules were digging in and not cutting. So, in addition to constantly burning my fingers, there were ugly scratches as well.
Bob Way
Canton, MI
Carole Valentine
>John's got it. Finish up each grit by turning the lathe off and sanding with the grain. Also, with fresh sandpaper, even good sandpaper, invariably there are a few oversized grains of abrasive that will leave deeper scratches. I usually swipe a new piece of sandpaper lightly across the edge of my lathe bed to knock off any oversized particles.
>Thanks for the replies. It never occurred to me to just sand normally. I just assumed since it was on the lathe to spin and sand. Sometimes it the simplist things that bring me to a dead stop...
Allen, I wouldn't sand my legs. I used to shave my legs though. When I used to race bicycles... :)
Joe
Don in Central Illinois
>ARGGH! More info than we needed.
Re: 100 grit- that's gravel on .....
Jamie Donaldson
>.. a paper backing! You should be able to start with 220, and as others have suggested, sand with the grain part of the time as you progress thru the grits.
ditto
robert davis
